Hi
I created a container using the Docker image dustynv/l4t-pytorch:r35.3.1 and am running Whisper inside the container.
I want to use a transformer inside this container.
If I install a transformer with pip, will this transformer use CUDA?
Or should I use the Docker image dustynv/transformers:r35.3.1?
Thank’s
It looks like Whisper uses PyTorch as inference engine
If so, it should run on the GPU since the container uses the package with CUDA support.
@Heartful-echo you can indeed just install transformers with pip3, and it will already use CUDA because the PyTorch in your container was built with CUDA enabled. Also, I do have a container for transformers that I use in a bunch of other stuff here:
@AastaLLL
Thank you for the interesting information.
@dusty_nv
I will use dustynv/transformers:r35.3.1.
Thank you for the great content.
system
Closed
October 25, 2023, 3:43am
7
