Would like to know how to connect a I2S microphone (e.g. SPH0645LM4H-B) to Xavier.
I see both CLK and DIN signals, but can’t find the ‘Word Select’ (WS).
Seems that there’s a typo in Jetson Xavier Series System-on-Module Data Sheet v0.9 - Pin D8 ‘Usage/Description’ is ‘I2S Audio Port 1 Data In’ - Should be Frame-Select ?
(Which is the ‘Word Select (WS)’ I was looking for.
Hello!
Yes you are correct, the “usage/description” field in table appears to be incorrect for the I2S1 signals. It should be …
Ball Signal Usage/Description
L14 I2S1_CLK I2S Audio Port 1 Clock
C7 I2S1_SDOUT I2S Audio Port 1 Data Out
D8 I2S1_FS I2S Audio Port 1 Left/Right Clock
H8 I2S1_SDIN I2S Audio Port 1 Data In
So yes D8 is the correct pin from the word-clock (frame-sync).
We will get this corrected.
Regards,
Jon
Does the microphone SPH0645LM4H-B work with Xavier?
Hello!
I don’t see why this would not work and in fact I know that others have had this working on Jetson TX2 …
https://devtalk.nvidia.com/default/topic/1032970/jetson-tx2/i2s-mic-with-tx2/
So it should work fine on Jetson Xavier as well.
Regards,
Jon
Hi Jonathan,
Thank you for your response.
May be you as well know sensors i2c for pressure/himidity/temperature/co2/o2 that are likely to work?
Thanks,
Andrei
Hi Andrei,
I can’t say that I have tested any of those sensors, however, if they are standard I2C devices I don’t see why they would not work.
Regards,
Jon
And drivers? Wont custom intrinsic drivers be required to read from connected sensors?
Hello Andrei,
Right ideally there should be a Linux driver available. If these devices are supported by Linux (which I was assuming is the case), then there should be a Linux driver available.
Regards
Jon
I procured dht11 sensor that has 3 pins: gnd, data,vcc.
could you advise to which pins to connect it at Xavier pinout, please?
Hello!
Can you please post this question in a new thread? This is not related to I2S microphones and so will not be seen or easily found by other users. Typically, I handle anything audio related, but by starting a new thread then it will be sent to the appropriate person for dealing with sensors.
Jon
Hello!
I just wanted to let you know that with the release of JetPack 4.3 (L4T 32.3.1) we now have a tool for configuring the 40-pin header on Jetson and we have included a configuration for the Adafruit SPH0645LM4H I2S Mic. Please see …
Regards,
Jon
