Hello Dieter,
The best reference for configuring the pinmux for Nano is the following …
Please note that although the above refers to the 40-pin header found on the devkit, the procedure is still relevant to the production version. However, you will need to …
- Use the module pinmux spreadsheet for the Nano module [0] and not the one for the Nano devkit.
- The module pinmux does not have a configuration for the Auvidea carrier board. So you may wish to ask Auvidea if they maintain a version for their carrier board. In fact, you may wish to ask them if they have the necessary devicetree files which contain an update pinmux for their carrier board.
- If you are using L4T r32.3+ then it is no longer necessary to update the U-Boot pinmux as described in the above document, only the C-Boot pinmux.
With regard, to the I2S slave/master mode, for each I2S interface there is an amixer control that can be used to change this from userspace.
$ amixer -c tegrasndt210ref cget name="I2S4 codec master mode"
Set Tegra as master, codec as slave …
$ amixer -c tegrasndt210ref cset name="I2S4 codec master mode" cbs-cfs
Set Tegra as slave, codec as master …
$ amixer -c tegrasndt210ref cset name="I2S4 codec master mode" cbm-cfm
Or you can change the default via device-tree [1].
Regards,
Jon
[0] https://developer.nvidia.com/jetson-nano-pinmux
[1] Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
