Thanks for the reply. could you tell how to enable I2S interface to be tmd? I am assuming depending the intput format either tdm or i2s . i need config I2S interface differently ?
By configuring the I2S interface for DSP-A mode, you are configuring it for TDM. So the instructions above will configure for TDM using DSP-A mode timing.
We just got our michphone board back. I dont see the fs clock during the recording. I am using Jetback 4.3. is I2S4 not enabled by default still ? it is known isssue in Jetpack 4.2.1.
To enable I2S4 with JetPack 4.2.1, I need update “pinmux-config-p3450-porg.h” and recompile the u-boot. do we still need this workaround with Jetpack 4.3 release?
The I2S4 interface is not enabled by default. However, starting with Jetpack 4.3 we have included a tool to help configure the pins on the 40-pin header …
Note that the first command above is a workaround for an issue in Jetpack 4.3 and will be fixed in future releases. You only need to execute that command once.
vaitl@11223301010003f9:~$ sudo /opt/nvidia/jetson-io/config-by-function.py -o dtb i2s4
File “/opt/nvidia/jetson-io/config-by-function.py”, line 92, in
main()
File “/opt/nvidia/jetson-io/config-by-function.py”, line 76, in main
jetson = board.Board()
File “/opt/nvidia/jetson-io/Jetson/board.py”, line 147, in init
self.name = _board_get(self.compat)
File “/opt/nvidia/jetson-io/Jetson/board.py”, line 81, in _board_get
raise RuntimeError(“No board data found!”)
RuntimeError: No board data found!
I run
1.sudo cp -v /boot/tegra210-p3448-0000-p3449-0000-[ab]0[012].dtb /boot/dtb/
2.sudo find /opt/nvidia/jetson-io/ -mindepth 1 -maxdepth 1 -type d -exec touch {}/init.py ;
3.sudo /opt/nvidia/jetson-io/config-by-function.py -o dtb i2s4
step 3 give me same err
vaitl@11223301010003f9:/boot/dtb$ sudo /opt/nvidia/jetson-io/config-by-function.py -o dtb i2s4
main()
There are a couple different versions of the Jetson Nano and starting with L4T release 32.3.1 the compatible string should reflect the specific version (a02, b01, etc). So it would appear that you are using a DTB from an earlier release because jetson-io itself was only released with 32.3.1.
1.Thanks, could you please be specific . which Jetpack release should I try for Jetson latest NANO production module ?900-13448-0020-000 . i
2.is this dtb tegra210-p3448-0002-p3449-0000-b00.dtb correct ? could you send me yours ?
3.can I use older rootfs ? does rootfs matter ?
some more inforation, i was using sdk manager to download Jetpack 4.3 and use flash.sh the module .(Not dev kits) This is the latest release. what else did I miss ?
Yes, you should use Jetpack 4.3. The correct DTB will be flashed by the flashing script. It is best to reflash the board rather than distribute DTBs, because there are a couple different versions of Nano and so we need the flash script to flash the appropriate DTB for you board. All versions of the Jetson Nano are supported by jetson-io and so I have no concerns that you board is not supported.
Somehow you have ended with an old DTB which I presume has come from an older release. Have you made any modifications to the release before flashing? If so I would just download jetpack and try flashing again.
I have not tried using an older rootfs with the current release so I am not sure if there could be any issues using an older rootfs. I would not expect that to cause an issue with the DTB, but I am not sure if there could be other issues. So it is probably best to use the rootfs that comes with jetpack.
I am using Jetpack 4.3 and I installed some lib into rootfs. Is there anyting you want to check on my device so I can check if the file is used from older version ?
My hardware setup is . I put Jetson production module plugin into the Jetson nano dev kit’s carrier board. I will reflash with sdmanager . but I remembered that I tried before it was the same problem.
Sorry, I realised that you are using the eMMC version of the Nano module. This is not supported by jetson-io and so we cannot use it to configure the IOs. So what you need to do is …
Use the pinmux spreadsheet to configure the pins as needed.
Click the ‘Generate DT’ button to export the pin configuration (it will output some device-tree source files)
Update the DT files Linux_for_Tegra/sources/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi and Linux_for_Tegra/sources/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi with the newly created files.
Rebuild the kernel DTBs [0]
Copy the DTB to the Linux_for_Tegra/kernel/dtb directory and reflash.
