I’m curious if the following works with the latest version:
% cat lowerror.f90
module low_mod
implicit none
private
public :: vd
public :: assignment(=)
public :: operator(-), operator(/)
integer, parameter :: NMax = 19, r8 = selected_real_kind(15,100)
type vd
real(r8) :: value
real(r8) :: deriv(NMax)
integer :: ind(NMax)
integer :: nderiv = -1
end type vd
interface assignment(=)
module procedure nv1, nvi
end interface
interface operator(-)
module procedure vmv
end interface
contains
pure subroutine ad(r,n,ind)
type(vd), intent(out) :: r
integer, intent(in) :: n
integer, intent(in) :: ind(:)
r%nderiv=n
if (n > 0) then
r%ind(1:n)=ind(1:n)
r%deriv(1:n)=0._r8
end if
end subroutine ad
elemental subroutine mv(v1,v2)
type(vd), intent(inout) :: v1
type(vd), intent(in) :: v2
type(vd) :: r
integer :: n, i, j
call nv2(r,v1,v2)
n = r%nderiv
r%deriv(1:n) = 0._r8
r%value = v1%value - v2%value
j = 0
do i = 1, v1%nderiv
do j = j+1, n
if (v1%ind(i) == r%ind(j)) then
r%deriv(j) = v1%deriv(i)
exit
end if
end do
end do
j = 0
do i = 1, v2%nderiv
do j = j+1, n
if(v2%ind(i) == r%ind(j)) then
r%deriv(j) = r%deriv(j) - v2%deriv(i)
exit
end if
end do
end do
call nv1(v1,r)
end subroutine mv
elemental subroutine nv1(r,v)
call ad(r,v%nderiv,v%ind)
r%value = v%value
r%deriv(1:r%nderiv) = v%deriv(1:v%nderiv)
end subroutine nv1
elemental subroutine nv2(r,v1,v2)
type(vd), intent(in) :: v1, v2
integer :: n, i1, i2, n1, n2
integer, allocatable :: itab(:)
n1 = v1%nderiv
n2 = v2%nderiv
allocate(itab(n1+n2))
n = 0
i1 = 1
i2 = 1
do
if (i1 > n1) then
itab(n+1:n+1+n2-i2) = v2%ind(i2:n2)
n = n + 1+n2-i2
exit
else if (i2 > n2) then
itab(n+1:n+1+n1-i1) = v1%ind(i1:n1)
n = n + 1+n1-i1
exit
else if (v1%ind(i1) == v2%ind(i2)) then
n = n + 1
itab(n) = v1%ind(i1)
i1 = i1 + 1
i2 = i2 + 1
else if (v1%ind(i1) < v2%ind(i2)) then
n = n + 1
i1 = i1 + 1
else
n = n + 1
itab(n) = v2%ind(i2)
i2 = i2 + 1
end if
end do
call ad(r,n,itab)
deallocate(itab)
end subroutine nv2
elemental subroutine nvi(r,c)
integer, intent(in) :: c
call ad(r,0,(/0/))
r%value = c
end subroutine nvi
elemental function vmv(v1,v2) result(r)
type(vd), intent(in) :: v1,v2
type(vd) :: r
call nv1(r,v1)
call mv(r,v2)
end function vmv
end module low_mod
program lowerror
use low_mod
implicit none
call vdtest(1000)
contains
subroutine vdtest(nx)
integer, intent(in) :: nx
type(vd), allocatable :: p(:), v(:)
allocate(p(nx),v(nx-1))
p = 0
v = p(1:nx-1) - p(2:nx)
end subroutine vdtest
end program lowerror
% pgf95 -o lowerror lowerror.f90
Lowering Error: array upper bound is not a symbol for datatype 54
Lowering Error: array extnt is not a symbol for datatype 54
PGF90-F-0000-Internal compiler error. Errors in Lowering 2 (lowerror.f90: 145)
PGF90/x86-64 Linux 8.0-5: compilation aborted
% pgf95 -V
pgf95 8.0-5 64-bit target on x86-64 Linux -tp core2-64
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2009, STMicroelectronics, Inc. All Rights Reserved.
