I’m pretty sure this code violates a constraint on equivalence in the Fortran standard, but you could say any ICE is a bug, so I wanted to bring it to your attention. I realize I’m using an old version of pgf90, so perhaps this issue has been fixed (i.e., error message instead of ICE) in the latest release.
% pgf90 -V
pgf90 8.0-5 64-bit target on x86-64 Linux -tp core2-64
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2009, STMicroelectronics, Inc. All Rights Reserved.
% cat bug.f90
module moda
integer, parameter :: c1 = 203, c2 = 16, c3 = 16, c4 = 7, c5 = 140
integer, parameter :: c6 = 10, c7 = 14, c8 = 12, c9 = 6, c10 = 8
integer, parameter :: c11 = 4, c12 = 2, c13 = 22, c14 = 38, c15 = 52
integer, parameter :: c16 = 68, c17 = 76, c18 = 88, c19 = 96
integer, parameter :: c20 = 108, c21 = 114, c23 = 122, c24 = 130
integer, parameter :: c25 = 134, c26 = 136, c27 = 138
end module moda
module modb
real :: mbv1(c6), mbv2(c6), mbv3(5,13,c6), mbv4(65,c6)
real :: mbv5(5,13:59,c6), mbv6(235,c6), mbv7(19,c6), mbv8(19,c6)
real :: mbv9(10,c6), mbv10(4,c6)
equivalence (mbv3(1,1,1),mbv4(1,1)), (mbv5(1,13,1),mbv6(1,1))
end module modb
module modc
use moda, only : c2, c3
integer :: mcv1(c3)
real :: mcv2(181)
real :: mcv3(c3*c2)
end module modc
module modd
use modc, only: mcv1
implicit none
contains
subroutine sub1(s1arg)
real, intent(out) :: s1arg(:,:)
call sub1sub
contains
subroutine sub1sub
use moda, only : c6
use modb, only : mbv3, mbv4, mbv5, mbv6, mbv7, mbv8, mbv9, mbv10
integer :: i, j, k
do i = 1, 100
j = 2
do k = 1, c6
s1arg(i,k) = mbv4(j,k)
end do
end do
print *, s1arg
end subroutine sub1sub
end subroutine sub1
end module modd
module mode
use modd, only: sub1
implicit none
contains
subroutine sub2(s2arg)
use moda, only : c5
integer, intent(in) :: s2arg
real :: x(s2arg+1,c5)
call sub1(x)
end subroutine sub2
end module mode
module modf
use mode, only: sub2
implicit none
contains
subroutine sub3()
call sub2(100)
end subroutine sub3
end module modf
program ipa_bug
use modf
call sub3
end program ipa_bug
% pgf90 -fast -Mipa=fast -o bug bug.f90
IPA: Recompiling bug.o: new IPA information
Lowering Error: unexpected symbol type alias(23)
PGF90-F-0000-Internal compiler error. Errors in Lowering 4 (bug.f90: 37)
PGF90/x86-64 Linux 8.0-5: compilation aborted
child process exit status 2: /usr/local/pgilinux-805/linux86-64/8.0-5/bin/pgf90
– Steve
