Hello, I’d like to follow up on a topic that has been closed: Match NvDsFrameMeta with their original gstreamer Buffer
I am sending multiple numpy images through a pipeline.
I use appsrc
to feed numpy arrays to my pipeline:
img = cv2.imread("/opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.jpg")
img = cv2.resize(img, (1080, 1920))
img = cv2.cvtColor(img, cv2.COLOR_BGR2RGBA)
buffer = Gst.Buffer.new_wrapped(img.tobytes())
self.source_bin_appsrc.emit("push-buffer", buffer)
The pipeline works fine, and I am able to retrieve the numpy image as well as the metadata from an object of type NvDsBatchMeta
The problem is that once I get the NvDsBatchMeta
I need to know what was the original numpy frame that this metadata refers to. In this case, I can’t simply download the image again from the pipeline.
The reason is the following: I am implementing a REST API. Suppose I have two users, user_A and user_B. They both send their images image_A and image_B to my API. My API sends the image to the pipeline. At the end of the pipeline I get the metadata for each image. However, how can I know what are the metadata that I need to send back to user_A, and what are the metadata for user_B?
I need to store some value into the image. Example: if I could attach to image_A the value user=user_A
, then, at the end of the pipeline, when I get the metadata, I could do something like metadata.user
and get the user that needs to receive the metadata.
In the post I linked above, @yuweiw said that: “You can consider using NvDsUserMeta to add your own tag for each gstbuffer through the probe function.”. However, how can I create a NvDsFrameMeta with attached NvDsUserMeta from a numpy array and send it to the pipeline?
