Memory error happen because ‘extractBits’ function’s result was wrong.
After some test, i found out if i added something to delay under that function, result will be right and no more error.
So i think maybe because other function was run before ‘extractBits’ function done.
But as i remember correctly, kernels are executed sequentially by default(not using stream). So i don’t know what is problem.
Here is source code:
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include <stdlib.h>
#define CHECK(call)\
const cudaError_t error = call;\
if (error != cudaSuccess)\
fprintf(stderr, "Error: %s:%d, ", __FILE__, __LINE__);\
fprintf(stderr, "code: %d, reason: %s\n", error,\
cudaGetErrorString(error));\
exit(1);\
struct GpuTimer
cudaEvent_t start;
cudaEvent_t stop;
GpuTimer()
cudaEventCreate(&start);
cudaEventCreate(&stop);
~GpuTimer()
cudaEventDestroy(start);
cudaEventDestroy(stop);
void Start()
cudaEventRecord(start, 0);
cudaEventSynchronize(start);
void Stop()
cudaEventRecord(stop, 0);
float Elapsed()
float elapsed;
cudaEventSynchronize(stop);
cudaEventElapsedTime(&elapsed, start, stop);
return elapsed;
// Sequential Radix Sort
// "const uint32_t * in" means: the memory region pointed by "in" is read-only
void sortByHost(const uint32_t * in, int n,
uint32_t * out)
int * bits = (int *)malloc(n * sizeof(int));
int * nOnesBefore = (int *)malloc(n * sizeof(int));
uint32_t * src = (uint32_t *)malloc(n * sizeof(uint32_t));
uint32_t * originalSrc = src; // To free memory later
memcpy(src, in, n * sizeof(uint32_t));
uint32_t * dst = out;
// Loop from LSB (Least Significant Bit) to MSB (Most Significant Bit)
// In each loop, sort elements according to the current bit from src to dst
// (using STABLE counting sort)
for (int bitIdx = 0; bitIdx < sizeof(uint32_t) * 8; bitIdx++)
// Extract bits
for (int i = 0; i < n; i++)
bits[i] = (src[i] >> bitIdx) & 1;
// Compute nOnesBefore
nOnesBefore[0] = 0;
for (int i = 1; i < n; i++)
nOnesBefore[i] = nOnesBefore[i-1] + bits[i-1];
// Compute rank and write to dst
int nZeros = n - nOnesBefore[n-1] - bits[n-1];
int rank;
if (bits[i] == 0)
rank = i - nOnesBefore[i];
else
rank = nZeros + nOnesBefore[i];
dst[rank] = src[i];
// Swap src and dst
uint32_t * temp = src;
src = dst;
dst = temp;
// Does out array contain results?
memcpy(out, src, n * sizeof(uint32_t));
// Free memory
free(originalSrc);
free(bits);
free(nOnesBefore);
__global__ void extractBits(uint32_t* in, int n, int* out, int bitId)
int i = blockIdx.x * blockDim.x + threadIdx.x;
if (i < n)
out[i] = (in[i] >> bitId) & 1;
__device__ int bCount = 0;
volatile __device__ int bDoneCount = 0;
__global__ void scanKernel(int* in, int n, int* out, volatile int* bSums)
__shared__ int blockId;
if (threadIdx.x == 0)
blockId = atomicAdd(&bCount, 1);
__syncthreads();
// 1. Each block loads data from GMEM to SMEM
extern __shared__ int s_data[];
int i = blockId * blockDim.x + threadIdx.x;
if (i < n)
if (i == 0)
s_data[threadIdx.x] = 0;
else
s_data[threadIdx.x] = in[i - 1];
__syncthreads();
// 2. Each block does scan with data on SMEM
for (int stride = 1; stride < blockDim.x; stride *= 2)
int neededVal;
if (threadIdx.x >= stride)
neededVal = s_data[threadIdx.x - stride];
__syncthreads();
s_data[threadIdx.x] += neededVal;
__syncthreads();
// 3. Each block write results from SMEM to GMEM
out[i] = s_data[threadIdx.x];
if (bSums != NULL)
bSums[blockId] = s_data[blockDim.x - 1];
if (blockId > 0)
while (bDoneCount < blockId) {}
bSums[blockId] += bSums[blockId - 1];
__threadfence();
bDoneCount += 1;
__syncthreads();
if (i + blockDim.x < n)
out[i + blockDim.x] += bSums[blockId];
__global__ void computeRank(uint32_t* in, int n, uint32_t* out, int* bits, int* nOnesBefore)
int nZeros = n - nOnesBefore[n - 1] - bits[n - 1];
if (i < n)
int rank;
if (bits[i] == 0)
else
out[rank] = in[i];
// Parallel Radix Sort
void sortByDevice(const uint32_t * in, int n, uint32_t * out, int blockSize)
uint32_t* src = (uint32_t*)malloc(n * sizeof(uint32_t));
// TODO
int *d_bits, *d_nOnesBefore;
size_t nBytes = n * sizeof(int);
CHECK(cudaMalloc(&d_bits, nBytes));
CHECK(cudaMalloc(&d_nOnesBefore, nBytes));
uint32_t * d_in, * d_out;
nBytes = n * sizeof(uint32_t);
CHECK(cudaMalloc(&d_in, nBytes));
CHECK(cudaMalloc(&d_out, nBytes));
CHECK(cudaMemcpy(d_in, in, nBytes, cudaMemcpyHostToDevice));
int gridSize = (n - 1) / blockSize + 1;
int* d_bSums;
if (gridSize > 1)
CHECK(cudaMalloc(&d_bSums, gridSize * sizeof(int)));
else
d_bSums = NULL;
size_t smem = blockSize * sizeof(int);
for (int bitId = 0; bitId < sizeof(uint32_t) * 8; bitId++)
// Extract bits
extractBits <<< gridSize, blockSize >>> (d_in, n, d_bits, bitId);
cudaDeviceSynchronize();
CHECK(cudaGetLastError());
// Dummy copy to delay, do nothing.
CHECK(cudaMemcpy(src, d_in, sizeof(uint32_t) * n, cudaMemcpyDeviceToHost));
scanKernel <<< gridSize, blockSize, smem >>> (d_bits, n, d_nOnesBefore, d_bSums);
int zero = 0;
CHECK(cudaMemcpyToSymbol(bCount, &zero, sizeof(int)));
CHECK(cudaMemcpyToSymbol(bDoneCount, &zero, sizeof(int)));
// Compute rank and write to d_out
computeRank <<< gridSize, blockSize >>> (d_in, n, d_out, d_bits, d_nOnesBefore);
// Swap d_in and d_out
uint32_t* temp = d_in;
d_in = d_out;
d_out = temp;
CHECK(cudaMemcpy(out, d_in, nBytes, cudaMemcpyDeviceToHost));
// Free memory
CHECK(cudaFree(d_bits));
CHECK(cudaFree(d_nOnesBefore));
CHECK(cudaFree(d_in));
CHECK(cudaFree(d_out));
if (gridSize > 1)
CHECK(cudaFree(d_bSums));
free(src);
// Radix Sort
void sort(const uint32_t * in, int n,
uint32_t * out,
bool useDevice=false, int blockSize=1)
GpuTimer timer;
timer.Start();
if (useDevice == false)
printf("\nRadix Sort by host\n");
sortByHost(in, n, out);
else // use device
printf("\nRadix Sort by device\n");
sortByDevice(in, n, out, blockSize);
timer.Stop();
printf("Time: %.3f ms\n", timer.Elapsed());
void printDeviceInfo()
cudaDeviceProp devProv;
CHECK(cudaGetDeviceProperties(&devProv, 0));
printf("**********GPU info**********\n");
printf("Name: %s\n", devProv.name);
printf("Compute capability: %d.%d\n", devProv.major, devProv.minor);
printf("Num SMs: %d\n", devProv.multiProcessorCount);
printf("Max num threads per SM: %d\n", devProv.maxThreadsPerMultiProcessor);
printf("Max num warps per SM: %d\n", devProv.maxThreadsPerMultiProcessor / devProv.warpSize);
printf("GMEM: %zu byte\n", devProv.totalGlobalMem);
printf("SMEM per SM: %zu byte\n", devProv.sharedMemPerMultiprocessor);
printf("SMEM per block: %zu byte\n", devProv.sharedMemPerBlock);
printf("****************************\n");
void checkCorrectness(uint32_t * out, uint32_t * correctOut, int n)
if (out[i] != correctOut[i])
printf("INCORRECT :(\n");
return;
printf("CORRECT :)\n");
void printArray(uint32_t * a, int n)
printf("%i ", a[i]);
printf("\n");
int main(int argc, char ** argv)
// PRINT OUT DEVICE INFO
printDeviceInfo();
// SET UP INPUT SIZE
//int n = 50; // For test by eye
int n = (1 << 24) + 1;
printf("\nInput size: %d\n", n);
// ALLOCATE MEMORIES
size_t bytes = n * sizeof(uint32_t);
uint32_t * in = (uint32_t *)malloc(bytes);
uint32_t * out = (uint32_t *)malloc(bytes); // Device result
uint32_t * correctOut = (uint32_t *)malloc(bytes); // Host result
// SET UP INPUT DATA
//in[i] = rand() % 255; // For test by eye
in[i] = rand();
//printArray(in, n); // For test by eye
// DETERMINE BLOCK SIZE
int blockSize = 256; // Default
if (argc == 2)
blockSize = atoi(argv[1]);
// SORT BY HOST
sort(in, n, correctOut);
//printArray(correctOut, n); // For test by eye
// SORT BY DEVICE
sort(in, n, out, true, blockSize);
//printArray(out, n); // For test by eye
checkCorrectness(out, correctOut, n);
// FREE MEMORIES
free(in);
free(out);
free(correctOut);
return EXIT_SUCCESS;
