The compiler can optimize its usage of a variable if you don’t inform it otherwise. The flag variable here is getting “optimized into a register”, meaning that when one thread updates the shared location, other threads don’t see it. You need to use a memory barrier of some sort, or else another approach is to use volatile decorator. This is a general principle to be aware of any time you are communicating between threads.
Example:
$ cat t2214.cu
#include <stdio.h>
#include <iostream>
#include <time.h>
// NVIDIA GeForce GTX 960M (compute/sm 50, 5x SM)
# define blocks 1
# define threads 1024
cudaError_t cudaStatus;
__global__ void blackcat(void) {
uint64_t n = 1000000000ull; // 1E9, 29.493572 s, test b = 2048
uint64_t a = 0;
#ifdef USE_VOLATILE
__shared__ volatile bool flag;
#else
__shared__ bool flag;
#endif
flag = false;
while (n --> 0) {
a++;
if (flag) {
break;
#ifdef USE_SHORT
if (threadIdx.x == 0 && a == 1000ull){
#else
if (threadIdx.x == 512 && a == 1000000ull) { // 1E6, just 1 block
#endif
printf("%lld\n", a);
flag = true;
int main() {
cudaEvent_t start, stop; // CUDA time
float time;
cudaEventCreate(&start);
cudaEventCreate(&stop);
cudaSetDevice(0);
cudaStatus = cudaGetLastError();
if (cudaStatus != cudaSuccess) {
fprintf(stderr, "cudaSetDevice failed! Do you have a CUDA-capable GPU installed?");
cudaEventRecord(start, 0);
blackcat << <blocks, threads >> > ();
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
cudaEventElapsedTime(&time, start, stop);
cudaEventDestroy(start);
cudaEventDestroy(stop);
printf("CUDA time is %f s\n", time/1000);
fprintf(stderr, "Kernel launch failed: %s\n", cudaGetErrorString(cudaStatus));
cudaDeviceSynchronize();
fprintf(stderr, "cudaDeviceSynchronize returned error code %d after launching addKernel!\n", cudaStatus);
return 0;
$ nvcc -o t2214 t2214.cu
$ time ./t2214
1000000
CUDA time is 8.491987 s
real 0m8.928s
user 0m5.706s
sys 0m3.203s
$ nvcc -o t2214 t2214.cu -DUSE_SHORT
$ time ./t2214
1000
CUDA time is 9.748708 s
real 0m10.186s
user 0m6.395s
sys 0m3.779s
$ nvcc -o t2214 t2214.cu -DUSE_VOLATILE
$ time ./t2214
1000000
CUDA time is 0.041508 s
real 0m0.447s
user 0m0.066s
sys 0m0.379s
$ nvcc -o t2214 t2214.cu -DUSE_VOLATILE -DUSE_SHORT
$ time ./t2214
1000
CUDA time is 0.004152 s
real 0m0.464s
user 0m0.046s
sys 0m0.397s
We see that in the non-volatile case, the “short” path is not shorter. In the volatile case, the short path is 10x shorter than the long path.
Robert_Crovella already provided an example of how to use volatile here:
The beauty of CUDA is that code is written from the viewpoint of a single thread, allowing the actual degree of parallelism to be configured independently of the code at run time.
The semantics of the volatile modifier in C++ are roughly “this data object is modified by an agent outside the current thread of execution”. Which is exactly what happens here: For the vast majority of threads, the thread writing flag is different from the thread reading flag.
As a consequence of the use of volatile, the compiler needs to generate code such that every textual access to such an object results in an actual access to the physical object, in this case a shared-memory location. The data cannot be pulled into a register for faster access.
Note that volatile is generally not a replacement for synchronization primitives but may be used in conjunction with them.
