I copied my issue from mxnet github repo: can not install mxnet on jetson nano, jetpack 4.3, mxnet 1.4 · Issue #17923 · apache/mxnet · GitHub
System info
jetson nano Jetpack 4.3
python3
mxnet 1.4
cuda 10.0
Description
Try to install mxnet on jetson nano, according to mxnet jetson_setup guide, during installation, no error raised, but when I import mxnet in python3, “Segmentation fault (core dumped)”
Error Message
root@jetbot:/home/jetbot/Downloads# python3
Python 3.6.9 (default, Nov 7 2019, 10:44:02)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import mxnet
To Reproduce
My installation procedure:
- install dependencies:
sudo apt update
sudo apt -y install \
build-essential \
git \
graphviz \
libatlas-base-dev \
libopencv-dev \
python3-pip
sudo pip3 install --upgrade \
pip \
setuptools
sudo pip3 install \
graphviz==0.8.4 \
jupyter \
numpy==1.18.2
a little different form official guide, which I use pip3 because I need to use python3, and the numpy version is 1.18.2 rather than 1.15.2 because the later pip install suggested to do so.
- clone the repo
git clone --recursive https://github.com/apache/incubator-mxnet.git mxnet
- environment
export PATH=/usr/local/cuda/bin:$PATH
export MXNET_HOME=$HOME/mxnet/
export PYTHONPATH=$MXNET_HOME/python:$PYTHONPATH
- check cuda version
nvcc --version
we can get:
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Mon_Mar_11_22:13:24_CDT_2019
Cuda compilation tools, release 10.0, V10.0.326
- download the whl file and libmxnet.so
wget -c https://s3.us-east-2.amazonaws.com/mxnet-public/install/jetson/1.4.0/mxnet-1.4.0-cp36-cp36m-linux_aarch64.whl # I'm using python3.6
wget -c https://s3.us-east-2.amazonaws.com/mxnet-public/install/jetson/1.4.1/libmxnet.so
mkdir mxnet/lib
mv libmxnet.so mxnet/lib # put this file in lib
- install the whl
sudo pip install mxnet-1.4.0-cp27-cp27mu-linux_aarch64.whl
- try to import
>>> import mxnet
What have you tried to solve it?
- try to build from source, it took me 2 hours and exited with error (sorry I forget to log the error info)
- reinstall the os, reflash the image, and try the jetson_setup guide again.
