I am using IMX334 sensor with Xavier nx . When I am using device in auto exposure mode at day time it is working fine but while at night time it is changing gain continuously and I can see flicker in my stream.
Could you limit the gain/exposure by “gainrange/exposuretimerange” to max to check.
nvidia@tegra-ubuntu:~$ gst-inspect-1.0 nvarguscamerasrc
Factory Details:
Rank primary (256)
Long-name NvArgusCameraSrc
Klass Video/Capture
Description nVidia ARGUS Camera Source
Author Viranjan Pagar <vpagar@nvidia.com>, Amit Pandya <apandya@nvidia.com>
exposuretimerange : Property to adjust exposure time range in nanoseconds
Use string with values of Exposure Time Range (low, high)
in that order, to set the property.
eg: exposuretimerange="34000 358733000"
flags: readable, writable
String. Default: null
gainrange : Property to adjust gain range
Use string with values of Gain Time Range (low, high)
eg: gainrange="1 16"
