I got a SG2-IMX390C-MIPI since it is listed on the Jetson Partner Supported Cameras website. I am running Jetpack 5.1.2 on a Orin Nano 8GB developer kit. How can i get the camera running?
Follow the advice on Configuring the Jetson Expansion Headers — Jetson Linux Developer Guide documentation
This adds the imx390 as an available device.
Run sudo /opt/nvidia/jetson-io/jetson-io.py
Then choose CSI setup. If you followed the website above the 7th item will be the IMX390.
- Camera Dual IMX274
- Camera IMX274
- Jetson Camera Dual-IMX274
- Jetson Camera E3331 module
- Jetson Camera E3333 module
- Jetson Camera IMX185
- Jetson Camera IMX390
Sorry image above is from a web site so doesn’t show all the options on a Jetson Orin Nano
Save pin changes
Save and reboot
That means that i have to create a Custom Device Tree Overlay (dtbo file), right? Is it possible to use a similar one as the stock AGX Orin file? Which changes are necessary to adapt the file to a Orin nano?
here’s IMX219 camera driver, which by default supported on Orin Nano,
$public_sources/kernel_src/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-camera-rbpcv2-imx219.dtsi
Sorry @felix.krabbes.lzc I am using dual imx219 cameras so can’t help on your 390. I thought the explanation given in the link I sent was something I could follow and I am a linux novice. Give it a go.
I am using a IMX390. Is it possible to use the IMX219 driver? This site
states that is supported.
hello felix.krabbes.lzc,
here’s IMX390 driver supported on AGX Orin.
$public_sources/kernel_src/hardware/nvidia/platform/t23x/common/kernel-dts/t234-common-modules/tegra234-camera-imx390-a00.dtsi
according to this…
it doesn’t looks like the one as same as we’re supported on developer kits.
may I know who’s your sensor vendor? did they also provide the dtbo file to enable the sensor driver?
The vendor is sensing-world. I could not find a driver on their website.
There is a similar Model from Seeed Studio. Has anybody this Sensor running?
