Hi everyone,
Has anyone successfully connected an IMX477 camera to the Jetson Orin Nano running JetPack 6.1?
I have connected the camera and managed to capture images, but the quality is very poor. The camera I am using is an original IMX477 from Arducam.
Any suggestions on improving the image quality or troubleshooting tips?
Hello @Narek.Mn
What GStreamer pipeline, command, or application are you using to capture images?
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
I got the imx219 up and the image has some issues, what problems does yours have?
In another post I started you can see the screen shot.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),format=NV12,width=640,height=480' ! nvvidconv ! videoconvert ! autovideosin
fred@orin1:/boot/extlinux$ dpkg-query --show nvidia-l4t-core
nvidia-l4t-core 36.4.0-20240912212859
fred@orin1:/boot/extlinux$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.0, GCID: 37537400, BOARD: generic, EABI: aarch64, DATE: Fri Sep 13 04:36:44 UTC 2024
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
fred@orin1:/boot/extlinux$ cat extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL prima…
Got a USB camera up and running, quality is very good. Problem with that is latency, so we really need the CSI interfaces up.
Thanks for provide the detailed answer. It works.
reduslewar:
It works.
Glad it works, are you using csi0 or csi1. Does you video look good? I tried 2 cameras and both have the same bad visual effects. I am assuming yours looks perfect, if so I will just get imx477 cameras that might be faster than trying to debug this.
Hello Eduardo,
Thank you for reaching out! To capture images, I am using the following GStreamer pipeline:
bash
#!/bin/bash
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1' ! nvvidconv flip-method=2 ! xvimagesink
#gst-launch-1.0 nvarguscamerasrc ispdigitalgainrange='1 1' ! capsfilter caps='video/x-raw(memory:NVMM),width=(int)1920,height=(int)1080,format=(string)NV12,framerate=(fraction)30/1' ! nvvidconv flip-method=2 ! xvimagesink -e
Additionally, I use the jetson-io.py script to configure the camera on the DevKit, ensuring proper setup and integration.
Let me know if you need more details!
Best regards,
Narek
@Narek.Mn
Thank you very much for posting the pipeline, that cured my problems. My pipelines did not work as good as the one you posted. IMX219 cam.
