How to load the overlay for the IMX219 camera in jetpack 6
fred@orin1:/boot/extlinux$ dpkg-query --show nvidia-l4t-core
nvidia-l4t-core	36.4.0-20240912212859
fred@orin1:/boot/extlinux$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.0, GCID: 37537400, BOARD: generic, EABI: aarch64, DATE: Fri Sep 13 04:36:44 UTC 2024
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
fred@orin1:/boot/extlinux$ cat extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd
      APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
#      sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
#    MENU LABEL backup kernel
#    LINUX /boot/Image.backup
#    INITRD /boot/initrd
#    APPEND ${cbootargs}
Where is it loading the .dtb, I don’t see that in the .conf. So what is up with this. I cannot find any reference in the docs for adding overlay.
I can see all the overlays, however .conf does not have any reference to loading the main .dtb
tegra234-p3767-camera-p3768-imx219-A.dtbo
fred@orin1:/boot/extlinux$ gst-inspect-1.0 nvarguscamerasrc
Factory Details:
  Rank                     primary (256)
  Long-name                NvArgusCameraSrc
  Klass                    Video/Capture
  Description              nVidia ARGUS Camera Source
  Author                   Viranjan Pagar <vpagar@nvidia.com>, Amit Pandya <apandya@nvidia.com>
Plugin Details:
  Name                     nvarguscamerasrc
  Description              nVidia ARGUS Source Component
  Filename                 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
  Version                  1.0.0
  License                  Proprietary
  Source module            nvarguscamerasrc
  Binary package           NvARGUSCameraSrc
  Origin URL               http://nvidia.com/
GObject
 +----GInitiallyUnowned
       +----GstObject
             +----GstElement
                   +----GstBaseSrc
                         +----GstNvArgusCameraSrc
Pad Templates:
  SRC template: 'src'
    Availability: Always
    Capabilities:
      video/x-raw(memory:NVMM)
                  width: [ 1, 2147483647 ]
                 height: [ 1, 2147483647 ]
                 format: { (string)NV12 }
              framerate: [ 0/1, 2147483647/1 ]
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
  SRC: 'src'
    Pad Template: 'src'
Element Properties:
  acquire-wait        : Set the waiting time for the acquireFrame before timeout. Default 5000000000 (in nanosec)
                        flags: readable, writable
                        Unsigned Integer64. Range: 5000000000 - 18446744073709551615 Default: 5000000000
  aeantibanding       : property to set the auto exposure antibanding mode
                        Enum "GstNvArgusCamAeAntiBandingMode" Default: 1, "AeAntibandingMode_Auto"
                           (0): AeAntibandingMode_Off - GST_NVCAM_AEANTIBANDING_OFF
                           (1): AeAntibandingMode_Auto - GST_NVCAM_AEANTIBANDING_AUTO
                           (2): AeAntibandingMode_50HZ - GST_NVCAM_AEANTIBANDING_50HZ
                           (3): AeAntibandingMode_60HZ - GST_NVCAM_AEANTIBANDING_60HZ
  aelock              : set or unset the auto exposure lock
                        Boolean. Default: false
  aeregion            : Property to set region of interest for auto exposure
                        with values of ROI coordinates (left, top, right, bottom)
                        and weight (float number) in that order, to set the property
                        use for example: aeregion="0 0 256 256 1"
                        String. Default: null
  awblock             : set or unset the auto white balance lock
  blocksize           : Size in bytes to read per buffer (-1 = default)
                        Unsigned Integer. Range: 0 - 4294967295 Default: 4096
  do-timestamp        : Apply current stream time to buffers
                        Boolean. Default: true
  ee-mode             : property to select edge enhnacement mode
                        Enum "GstNvArgusCamEEMode" Default: 1, "EdgeEnhancement_Fast"
                           (0): EdgeEnhancement_Off - GST_NVCAM_EE_OFF
                           (1): EdgeEnhancement_Fast - GST_NVCAM_EE_FAST
                           (2): EdgeEnhancement_HighQuality - GST_NVCAM_EE_HIGHQUALITY
  ee-strength         : property to adjust edge enhancement strength
                        Float. Range:              -1 -               1 Default:              -1
  event-wait          : Set the waiting time for the event before timeout. Default 3000000000 (in nanosec)
                        Unsigned Integer64. Range: 3000000000 - 18446744073709551615 Default: 3000000000
  exposurecompensation: property to adjust exposure compensation
                        Float. Range:              -2 -               2 Default:               0
  exposuretimerange   : Property to adjust exposure time range in nanoseconds
                        Use string with values of Exposure Time Range (low, high)
                        in that order, to set the property.
                        eg: exposuretimerange="34000 358733000"
  gainrange           : Property to adjust gain range
                        Use string with values of Gain Time Range (low, high)
                        eg: gainrange="1 16"
  ispdigitalgainrange : Property to adjust digital gain range
                        Use string with values of ISP Digital Gain Range (low, high)
                        eg: ispdigitalgainrange="1 8"
  name                : The name of the object
                        flags: readable, writable, 0x2000
                        String. Default: "nvarguscamerasrc0"
  num-buffers         : Number of buffers to output before sending EOS (-1 = unlimited)
                        Integer. Range: -1 - 2147483647 Default: -1
  parent              : The parent of the object
                        Object of type "GstObject"
  saturation          : Property to adjust saturation value
                        Float. Range:               0 -               2 Default:               1
  sensor-id           : Set the id of camera sensor to use. Default 0.
                        Integer. Range: 0 - 255 Default: 0
  sensor-mode         : Set the camera sensor mode to use. Default -1 (Select the best match)
                        Integer. Range: -1 - 255 Default: -1
  show-latency        : Show capture latency between start of frame and GstBuffer push
  silent              : Produce verbose output ?
  timeout             : timeout to capture in seconds (Either specify timeout or num-buffers, not both)
                        Unsigned Integer. Range: 0 - 2147483647 Default: 0
  tnr-mode            : property to select temporal noise reduction mode
                        Enum "GstNvArgusCamTNRMode" Default: 1, "NoiseReduction_Fast"
                           (0): NoiseReduction_Off - GST_NVCAM_NR_OFF
                           (1): NoiseReduction_Fast - GST_NVCAM_NR_FAST
                           (2): NoiseReduction_HighQuality - GST_NVCAM_NR_HIGHQUALITY
  tnr-strength        : property to adjust temporal noise reduction strength
  total-sensor-modes  : Query the number of sensor modes available. Default 0
                        flags: readable
  typefind            : Run typefind before negotiating (deprecated, non-functional)
                        flags: readable, writable, deprecated
  wbmode              : White balance affects the color temperature of the photo
                        Enum "GstNvArgusCamWBMode" Default: 1, "auto"
                           (0): off              - GST_NVCAM_WB_MODE_OFF
                           (1): auto             - GST_NVCAM_WB_MODE_AUTO
                           (2): incandescent     - GST_NVCAM_WB_MODE_INCANDESCENT
                           (3): fluorescent      - GST_NVCAM_WB_MODE_FLUORESCENT
                           (4): warm-fluorescent - GST_NVCAM_WB_MODE_WARM_FLUORESCENT
                           (5): daylight         - GST_NVCAM_WB_MODE_DAYLIGHT
                           (6): cloudy-daylight  - GST_NVCAM_WB_MODE_CLOUDY_DAYLIGHT
                           (7): twilight         - GST_NVCAM_WB_MODE_TWILIGHT
                           (8): shade            - GST_NVCAM_WB_MODE_SHADE
                           (9): manual           - GST_NVCAM_WB_MODE_MANUAL
Did find how to enable it. However this does not look very good.
Tried a different camera and its the same issue.
So, your problem is image quality?
If your imx219 lens module is different with PI V2 camera you need to modify the badge info in device tree to load default ISP parameters or consult with camera partner to run the tuning process for your module.
I found the issue and trying to pin it down with greater accuracy.
It seems like resources are not being released or something needs to be shut down gracefully.
Power cycle the board, launch pipeline from CLI an it works perfectly.
Now, close down pipeline and try to restart in same console, sometimes it will work and other times not. It will launch and not display properly when calling the pipeline from within a python script even after a reboot. I have not done this in C++ yet.
How about below command.
export DISPLAY=:0
gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! xvimagesink sync=false
That one is working very well, it can be stopped and restarted without any problems
Change the frame rate and it will launch but breaks on restart.
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=1280, height=720, framerate=60/1' ! nvvidconv ! xvimagesink sync=false
Added buffering and it will start fine after reboot but cannot be restarted after ctrl-c
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=1280, height=720, framerate=60/1' ! queue ! nvvidconv ! queue ! xvimagesink sync=false
Here is more detail on the system from jtop
How about others sensor mode like 1920x1080@30?
Same problems.
My thoughts point to resources that are not being closed or reinitialized properly when restarted. If the board is power cycled a pipeline that will not display properly when restarted will work just fine.
That rules out cables and such, this pattern holds when using imx219 sensors from different vendors so its not tied to a flaky camera. I have not tried a different model of camera, yet.
Still need help?
Please give the detail for the problem need help to clarify.
We only had one board and it had to be returned due to an issue. Just waiting on stock in the USA and when I get another board, then I will look at this again. Thank you for responding to this matter.
We are waiting on a board, it was the only one we had since it was a trial.
