I am running 35.3.1 on Orin Nano Dev Kit and trying to run Arducam IMX519 via MIPI interface. I get camera input via
FRAMERATE = 9
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=4656,height=3496,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=4656,height=3496,framerate=$FRAMERATE/1" ! nv3dsink
To run the pipeline in a python script, I replace sink with appsink and add queue but it doesn’t work. On terminal, the following command
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=4656,height=3496,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=4656,height=3496,framerate=$FRAMERATE/1"! queue ! appsink
gives this and hangs ( I am assuming it’s supposed to do that)
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4656 x 3496 FR = 10.000000 fps Duration = 100000000 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3840 x 2160 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 4656 H = 3496
seconds to Run = 0
Frame Rate = 10.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
My python code is as follows:
self.cap = cv2.VideoCapture("nvarguscamerasrc sensor-id=0 ! "
"video/x-raw(memory:NVMM),width=4656,height=3496,framerate=9/1 !"
"nvvidconv ! video/x-raw(memory:NVMM),width=4656,height=3496,framerate=9/1 !"
"queue ! appsink", cv2.CAP_GSTREAMER)
The error I get is
RuntimeError: Failed to open camera!
What things can I try and how to debug the issue? Is this still a camera driver issue or maybe the OpenCV, pipeline configuration problem? Thank you in advance.
