My jetson nano reboots itself after running a python file with openCV
My jetson nano 4GB just rebooted itself after running a python file with openCV . Other python files without openCV work fine , but something happens and the device hangs out and reboots for openCV . The python file is as simple as can be. I tried files with complex codes and that did’nt work of course! The file is here :-
import cv2
print(cv2.__version__)
dispW=640
dispH=480
flip=2
camSet='nvarguscamerasrc !  video/x-raw(memory:NVMM), width=3264, height=2464, format=NV12, framerate=21/1 ! nvvidconv flip-method='+str(flip)+' ! video/x-raw, width='+str(dispW)+', height='+str(dispH)+', format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink'
cam=cv2.VideoCapture(camSet)
while True:
    ret, frame=cam.read()
    cv2.imshow("PiCam", frame)
    cv2.moveWindow('PiCam',0,0)
    if cv2.waitKey(1)==ord('q'):
        break
cam.release()
cv2.destroyAllWindows()
At first I got some sort of error output and a dialogue box appeared stating “system program problem detected” and asked me whether I had to report it or not. After I declined , the terminal showed the following error:-
<pre>4.1.1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 3264 H = 2464
   seconds to Run    = 0
   Frame Rate = 21.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: ERROR OCCURRED
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (1757) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module nvarguscamerasrc0 reported: CANCELLED
GST_ARGUS: Cleaning up
(Argus) Error Timeout:  (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
(Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
(Argus) Error FileOperationFailed: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error FileOperationFailed: Receive worker failure, notifying 2 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error FileOperationFailed: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error FileOperationFailed: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error FileOperationFailed:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (886) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
[ERROR:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap.cpp (116) open VIDEOIO(CV_IMAGES): raised OpenCV exception:
OpenCV(4.1.1) /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can&apos;t find starting number (in the name of file): nvarguscamerasrc !  video/x-raw(memory:NVMM), width=3264, height=2464, format=NV12, framerate=21/1 ! nvvidconv flip-method=2 ! video/x-raw, width=640, height=480, format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink in function &apos;icvExtractPattern&apos;
  File &quot;OpenCV1.py&quot;, line 12, in &lt;module&gt;
    cv2.imshow(&quot;PiCam&quot;, frame)
cv2.error: OpenCV(4.1.1) /home/nvidia/host/build_opencv/nv_opencv/modules/highgui/src/window.cpp:352: error: (-215:Assertion failed) size.width&gt;0 &amp;&amp; size.height&gt;0 in function &apos;imshow&apos;
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
</pre>
After this when I run my program again my nano reboots itself. And then again, when I unplug the device power and plug it again , It constantly shows the same error. Kindly help me out of this mess.
Thank You
Please check if you are able to launch the camera in gst-launch-1.0 and see camera preview:
$ export DISPLAY=:0
$ gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memo
ry:NVMM),framerate=21/1,width=3264,height=2464' ! nvegltransform ! nveglglessink
Yeah, I tried that to but did’nt work and showed the following output :-
Invalid MIT-MAGIC-COOKIE-1 keynvbuf_utils: Could not get EGL display connection
(gst-launch-1.0:11916): GStreamer-WARNING **: 16:38:38.008: Invalid caps feature name: memo
ry:NVMM
WARNING: erroneous pipeline: could not link nvarguscamerasrc0 to nvegltransform0, neither element can handle caps video/x-raw, framerate=(fraction)21/1, width=(int)3264, height=(int)2464
Hello ,
I tested my IMX219-83 waveshare camera’s second camera and it worked perfectly. After that I noticed that we had to attach the GPIO wires that were given to the jetson nano board . After that both the cameras started working perfectly for some reason. I tested it with Opencv and it works like it used to. I still did’nt understand what had happened but I am glad it works now.
Thank for your help and support
