Hello everyone,
I am trying to opening Jetson TX2 onboard camera from Nsight. I have installed and build OpenCV with Jetpack 4.2 on Jetson TX2. My code is written in C++.
#include <iostream>
#include <opencv2/core.hpp>
#include <opencv2/videoio.hpp>
#include <opencv2/highgui.hpp>
using namespace cv;
int main(void)
Mat img;
cv::VideoCapture cap;
std::cout<<cv::getBuildInformation()<<std::endl;
const char* gst = "nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv video/x-raw(memory:NVMM),format=(string)I420 ! appsink";
cap.open(gst);
if(!cap.isOpened())
std::cout<<"Camera is not opened"<<std::endl;
unsigned int width = cap.get(CV_CAP_PROP_FRAME_WIDTH);
unsigned int height = cap.get(CV_CAP_PROP_FRAME_HEIGHT);
unsigned int pixels = width*height;
std::cout <<"Frame size : "<<width<<" x "<<height<<", "<<pixels<<" Pixels "<<std::endl;
cv::namedWindow("MyCameraPreview", CV_WINDOW_AUTOSIZE);
cv::Mat frame_in(width, height, CV_8UC3);
while(1)
if (!cap.read(frame_in))
std::cout<<"Capture read error"<<std::endl;
break;
else
std::cout<<"open window"<<std::endl;
cv::imshow("MyCameraPreview",frame_in);
cv::waitKey(1000/120); // let imshow draw and wait for next frame 8 ms for 120 fps
cap.release();
return 0;
I am able to build my code successfully. However, when I run my code remotely on Jetson TX2 from Nsight, I receive following error:
(DetectNet_v1:8932): GStreamer-CRITICAL **: 16:25:02.183: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2592 x 1944 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 2592 x 1458 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 22000, max 358733000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: PowerService: requested_clock_Hz=12096000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
GST_ARGUS: Cleaning up
GST_ARGUS:
PowerServiceHwVic::cleanupResources
CONSUMER: Done Success
GST_ARGUS: Done Success
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp, line 887
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
/home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp:887: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
Frame size : 0 x 0, 0 Pixels
(DetectNet_v1:8932): Gtk-WARNING **: 16:25:02.800: cannot open display:
logout
The problem is about GStreamer pipeline. However, when I checked opencv build settings, GStreamer is enabled. Here is the output:
General configuration for OpenCV 3.3.1 =====================================
Version control: 3.3.1-2-g31ccdfe11
Platform:
Timestamp: 2019-02-06T09:45:58Z
Host: Linux 4.9.140-tegra aarch64
CMake: 2.8.12.2
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: Release
CPU/HW features:
Baseline: NEON FP16
required: NEON
disabled: VFPV3
C/C++:
Built as dynamic libs?: YES
C++11: YES
C++ Compiler: /usr/bin/c++ (ver 7.3.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release):
Linker flags (Debug):
ccache: NO
Precompiled headers: NO
Extra dependencies: dl m pthread rt /usr/lib/aarch64-linux-gnu/libtbb.so
3rdparty dependencies:
OpenCV modules:
To be built: core flann imgproc ml objdetect photo video dnn imgcodecs shape videoio highgui superres ts features2d calib3d stitching videostab python2 python3
Disabled: js world
Disabled by dependency: -
Unavailable: cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev java viz
GUI:
QT: NO
GTK+ 2.x: YES (ver 2.24.32)
GThread : YES (ver 2.56.3)
GtkGlExt: NO
OpenGL support: NO
VTK support: NO
Media I/O:
ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver )
WEBP: build (ver encoder: 0x020e)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 - 4.0.9)
JPEG 2000: build (ver 1.900.1)
OpenEXR: NO
GDAL: NO
GDCM: NO
Video I/O:
DC1394 1.x: NO
DC1394 2.x: NO
FFMPEG: YES
avcodec: YES (ver 57.107.100)
avformat: YES (ver 57.83.100)
avutil: YES (ver 55.78.100)
swscale: YES (ver 4.8.100)
avresample: NO
GStreamer:
base: YES (ver 1.14.1)
video: YES (ver 1.14.1)
app: YES (ver 1.14.1)
riff: YES (ver 1.14.1)
pbutils: YES (ver 1.14.1)
OpenNI: NO
OpenNI PrimeSensor Modules: NO
OpenNI2: NO
PvAPI: NO
GigEVisionSDK: NO
Aravis SDK: NO
UniCap: NO
UniCap ucil: NO
V4L/V4L2: NO/YES
XIMEA: NO
Xine: NO
Intel Media SDK: NO
gPhoto2: NO
Parallel framework: TBB (ver 2017.0 interface 9107)
Trace: YES ()
Other third-party libraries:
Use Intel IPP: NO
Use Intel IPP IW: NO
Use VA: NO
Use Intel VA-API/OpenCL: NO
Use Lapack: NO
Use Eigen: YES (ver 3.3.4)
Use Cuda: NO
Use OpenCL: NO
Use OpenVX: NO
Use custom HAL: YES (carotene (ver 0.0.1))
Python 2:
Interpreter: /usr/bin/python2.7 (ver 2.7.15)
Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.15rc1)
numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
packages path: lib/python2.7/dist-packages
Python 3:
Interpreter: /usr/bin/python3 (ver 3.6.7)
Libraries: /usr/lib/aarch64-linux-gnu/libpython3.6m.so (ver 3.6.7)
numpy: /usr/lib/python3/dist-packages/numpy/core/include (ver 1.13.3)
packages path: lib/python3.6/dist-packages
Python (for build): /usr/bin/python2.7
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Matlab: Matlab not found or implicitly disabled
Documentation:
Doxygen: NO
Tests and samples:
Tests: YES
Performance tests: YES
C/C++ Examples: YES
Install path: /usr
cvconfig.h is in: /home/nvidia/build_opencv/build
Do you have any idea, why I am not able to open on-board camera?
Thank you very much
