I tried to run yolov3 but I failed. I don’t know what I should do :(
cae@cae-desktop:~/Downloads/darknet$ ./darknet detector demo cfg/coco.data cfg/yolov3.cfg yolov3.weights “nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720,format=(string)I420, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink”
returns
Loading weights from yolov3.weights…Done!
video file: nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720,format=(string)I420, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2592 x 1944 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 2592 x 1458 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 22000, max 358733000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 1
Output Stream W = 2592 H = 1458
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: PowerService: requested_clock_Hz=27216000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
GST_ARGUS: Cleaning up
GST_ARGUS:
PowerServiceHwVic::cleanupResources
CONSUMER: Done Success
GST_ARGUS: Done Success
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp, line 887
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
/home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp:887: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
Couldn’t connect to webcam.
: Resource temporarily unavailable
darknet: ./src/utils.c:256: error: Assertion `0’ failed.
Aborted (core dumped)
Actually, I could use onboard camera with this code(below).
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=640, height=480, framerate=30/1, format=NV12’ ! nvvidconv flip-method=2 ! nvegltransform ! nveglglessink -e
so I applied the code in yolov3 model. But…
cae@cae-desktop:~/Downloads/darknet$ ./darknet detector demo cfg/coco.data cfg/yolov3.cfg yolov3.weights “gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=640, height=480, framerate=30/1, format=NV12’ ! nvvidconv flip-method=2 ! nvegltransform ! nveglglessink -e”
returns
video file: gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=640, height=480, framerate=30/1, format=NV12’ ! nvvidconv flip-method=2 ! nvegltransform ! nveglglessink -e
(darknet:11513): GStreamer-CRITICAL **: 19:53:49.037: gst_element_make_from_uri: assertion ‘gst_uri_is_valid (uri)’ failed
OpenCV Error: Unspecified error (GStreamer: cannot find appsink in manual pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp, line 802
/home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp:802: error: (-2) GStreamer: cannot find appsink in manual pipeline
: No such file or directory
what’s wrong?
