i’m trying to run my code using onboard camera, but there’s error.
my code is
import cv2
print(cv2.version)
gst_str = ("nvarguscamerasrc ! video/x-raw(memory:NVMM), format=NV12, width=640, height=480, framerate=30/1 ! "
"nvvidconv ! video/x-raw, format=(string)BGRx ! "
"videoconvert ! video/x-raw, format=(string)BGR ! "
"appsink")
vidcap = cv2.VideoCapture(gst_str, cv2.CAP_GSTREAMER)
success,image = vidcap.read()
count = 0
success = True
while success:
cv2.imwrite(“frame%d.jpg” % count, image) # save frame as JPEG file
print ('Read a new frame: ', success)
count += 1
but when i run this code,
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2592 x 1944 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 2592 x 1458 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 22000, max 358733000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: PowerService: requested_clock_Hz=2016000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
what should i do?
