I’ve browed through a bunch of topics on this (a search capability or pinned topic would help!) and I’m still getting errors trying to read from the TX2 devkit onboard camera. The error I see is:
VIDEOIO ERROR: V4L: device nvcamerasrc fpsRange='30 30'! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)BGRx ! nvvidconv ! video/x-raw, format=(string)BGR ! nvvidconv ! video/x-raw, format=(string)BGR ! videoconvert ! appsink: Unable to query number of channels
Available Sensor modes :
2592 x 1944 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
2592 x 1458 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
1280 x 720 FR=120.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 1 WxH = 2592x1458 FrameRate = 30.000000 ...
OpenCV(3.4.1-dev) Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/opencv/modules/videoio/src/cap_gstreamer.cpp, line 890
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
OpenCV(3.4.1-dev) /home/nvidia/opencv/modules/videoio/src/cap_gstreamer.cpp:890: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
VIDEOIO ERROR: libv4l unable convert to requested pixfmt
VIDEOIO ERROR: libv4l unable to ioctl VIDIOCSPICT
VIDEOIO(cvCreateCapture_GStreamer(CV_CAP_GSTREAMER_V4L2, reinterpret_cast<char *>(index))): raised OpenCV exception:
As you can see I’m running my own build of OpenCV with GStreamer enabled (following jetsonhacks/buildOpenCVTX2), but no matter what I try I can’t get the pipeline to start.
That string works … once I realized I was calling VideoCapture.open() instead of VideoCapture.isOpen(). :facepalm:
Now I need to figure out why once my object tracker finds something it (a) cuts framerate WAY down; (b) stalls out after a few minutes, or (c) segfaults. But that’s not a problem with the string yet.
@toolelucidator You may provide more details of what you are doing (what commands, code…) and what errors you see, this may lead to better advice. You may also give details about your setup (dev kit, camera, opencv version, …).
Just guessing, does your opencv build support gstreamer ? Opencv provides a function named getBuildInformation() that returns a long string with build options, so you would print this. Python example:
how can i use onboard cam.
I’m using python3, opencv 3.4.0
Error message :
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp
, line 890
enCV exception:
/home/nvidia/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp:890: error: (-2) GStreamer: unable to
start pipeline
getBuildInformation() is following :
Video I/O:
DC1394: NO
FFMPEG: YES
avcodec: YES (ver 56.60.100)
avformat: YES (ver 56.40.101)
avutil: YES (ver 54.31.100)
swscale: YES (ver 3.1.101)
avresample: NO
GStreamer:
base: YES (ver 1.8.3)
video: YES (ver 1.8.3)
app: YES (ver 1.8.3)
riff: YES (ver 1.8.3)
pbutils: YES (ver 1.8.3)
libv4l/libv4l2: 1.10.0 / 1.10.0
v4l/v4l2: linux/videodev2.h
gPhoto2: NO
