Hello, I am new to using the Jetson TX2 and I have been trying for a long time to obtain a stream from the onboard camera using OpenCV but I have been running into countless issues. The code I used to attempt this is below.
#include <opencv2/core.hpp>
#include <opencv2/videoio.hpp>
#include <opencv2/highgui.hpp>
#include <iostream>
#include <stdio.h>
using namespace cv;
using namespace std;
int main(int, char**)
Mat frame;
//--- INITIALIZE VIDEOCAPTURE
VideoCapture cap;
// open the default camera using default API
// cap.open(0);
// OR advance usage: select any API backend
int deviceID = 1; // 0 = open default camera
int apiID = cv::CAP_ANY; // 0 = autodetect default API
// open selected camera using selected API
cap.open(deviceID, apiID);
// check if we succeeded
if (!cap.isOpened()) {
cerr << "ERROR! Unable to open camera\n";
return -1;
//--- GRAB AND WRITE LOOP
cout << "Start grabbing" << endl
<< "Press any key to terminate" << endl;
for (;;)
// wait for a new frame from camera and store it into 'frame'
cap.read(frame);
if (frame.empty()) {
cerr << "ERROR! blank frame grabbed\n";
break;
// show live and wait for a key with timeout long enough to show images
imshow("Live", frame);
if (waitKey(5) >= 0)
break;
// the camera will be deinitialized automatically in VideoCapture destructor
return 0;
The error I am receiving is
GStreamer-CRITICAL **: 15:52:08.328:
Trying to dispose element pipeline0, but it is in PAUSED instead of the NULL state.
You need to explicitly set elements to the NULL state before
dropping the final reference, to allow them to clean up.
This problem may also be caused by a refcounting bug in the
application or some element.
[ WARN:0] global /home/nvidia/OpenCV/workspace/opencv-4.5.0/modules/videoio/src/cap_gstreamer.cpp (888) open OpenCV | GStreamer warning: unable to start pipeline
(MC:12407): GStreamer-CRITICAL **: 15:52:08.328: Trying to dispose element videoconvert0, but it is in PLAYING instead of the NULL state. You need to explicitly set elements to the NULL state before dropping the final reference, to allow them to clean up. This problem may also be caused by a refcounting bug in the application or some element.
[ WARN:0] global /home/nvidia/OpenCV/workspace/opencv-4.5.0/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
(MC:12407): GStreamer-CRITICAL **: 15:52:08.328: Trying to dispose element appsink0, but it is in READY instead of the NULL state. You need to explicitly set elements to the NULL state before dropping the final reference, to allow them to clean up. This problem may also be caused by a refcounting bug in the application or some element.
[ WARN:0] global /home/nvidia/OpenCV/workspace/opencv-4.5.0/modules/videoio/src/cap_v4l.cpp (893) open VIDEOIO(V4L2:/dev/video1): can't open camera by index ERROR! Unable to open camera
(MC:12407): GStreamer-CRITICAL **: 15:52:08.336: gst_element_post_message: assertion 'GST_IS_ELEMENT (element)' failed
Any assistance in figuring out this problem would be appreciated.
