Hi all,
I am currently experiencing an error in obtaining the camera image through OpenCV. So seek help.
Device: Jetson Nano 4G
Code:
#include <opencv2/opencv.hpp>
#include <iostream>
int main() {
// Set GStreamer pipeline string
std::string pipeline = "nvarguscamerasrc sensor-id=0 ! \"video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1\" ! nvvidconv ! videoconvert ! appsink";
// Turn on the camera
cv::VideoCapture cap(pipeline, cv::CAP_GSTREAMER);
if (!cap.isOpened()) {
std::cerr << "Can't open camera" << std::endl;
return -1;
cv::Mat frame;
while (true) {
cap >> frame;
if (frame.empty()) {
std::cerr << "No frames captured" << std::endl;
break;
cv::imshow("Camera Feed", frame);
if (cv::waitKey(30) == 'q') {
break;
cap.release();
cv::destroyAllWindows();
return 0;
Using OpenCV, cap. isOpened() returns True, but reports an error when retrieving frames.Information output during runtime
[ WARN:0@30.319] global cap_gstreamer.cpp:1697 open OpenCV | GStreamer warning: unable to query duration of stream
(test:28379): GStreamer-CRITICAL **: 17:48:39.602: gst_caps_get_structure: assertion ‘GST_IS_CAPS (caps)’ failed
(test:28379): GStreamer-CRITICAL **: 17:48:39.602: gst_structure_get_int: assertion ‘structure != NULL’ failed
[ WARN:0@30.319] global cap_gstreamer.cpp:1707 open OpenCV | GStreamer warning: cannot query video width/height
(test:28379): GStreamer-CRITICAL **: 17:48:39.602: gst_structure_get_fraction: assertion ‘structure != NULL’ failed
[ WARN:0@30.319] global cap_gstreamer.cpp:1713 open OpenCV | GStreamer warning: cannot query video fps
[ WARN:0@30.319] global cap_gstreamer.cpp:1728 open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
(test:28379): GStreamer-CRITICAL **: 17:49:44.603: gst_sample_get_caps: assertion ‘GST_IS_SAMPLE (sample)’ failed
[ERROR:0@95.320] global cap_gstreamer.cpp:925 retrieveVideoFrame GStreamer: gst_sample_get_caps() returns NULL
I can use the following command to open the camera screen:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! “video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1” ! nvvidconv ! xvimagesink sync=false
Regrads
