the command below runs on command line and shows me the camera but when I want to read frames with python in opencv it doesn’t work.
gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! 'video/x-raw(memory:NVMM),width=3280, height=2464,framerate=21/1, format=NV12' ! nvvidconv flip-method=2 ! 'video/x-raw, width=816, height=616' ! nvvidconv ! nvegltransform ! nveglglessink -e
The code is below:
import cv2
class CSIRetriever:
def _gstreamer_pipeline(self):
return "gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! 'video/x-raw(memory:NVMM),width=3280, height=2464,framerate=21/1, format=NV12' ! nvvidconv flip-method=2 ! 'video/x-raw, width=816, height=616' ! nvvidconv ! nvegltransform ! nveglglessink -e ! appsink"
def __init__(self):
self.video_capture = cv2.VideoCapture(self._gstreamer_pipeline(), cv2.CAP_GSTREAMER)
def isAvailable(self)->bool:
if not self.video_capture.isOpened():
print("Couldn't open camera")
return False
return True
def get_frame(self):
ret_val=False
frame=None
if self.isAvailable():
try:
ret_val, frame = self.video_capture.read()
except:
return False, None
return ret_val, frame
def _show_camera(self):
window_title = "CSI Camera"
window_handle = cv2.namedWindow(window_title, cv2.WINDOW_AUTOSIZE)
# To flip the image, modify the flip_method parameter (0 and 2 are the most common)
try:
while True:
# Check to see if the user closed the window
# Under GTK+ (Jetson Default), WND_PROP_VISIBLE does not work correctly. Under Qt it does
# GTK - Substitute WND_PROP_AUTOSIZE to detect if window has been closed by user
if cv2.getWindowProperty(window_title, cv2.WND_PROP_AUTOSIZE) >= 0:
cv2.imshow(window_title, frame)
else:
break
keyCode = cv2.waitKey(10) & 0xFF
# Stop the program on the ESC key or 'q'
if keyCode == 27 or keyCode == ord('q'):
break
finally:
self.video_capture.release()
cv2.destroyAllWindows()
else:
print("Error: Unable to open camera")
if __name__ == "__main__":
cret=CSIRetriever()
cret._show_camera()
I would be grateful if you can help.
I am using 4GB ram version of jetson nano
