Socket read error. Camera Daemon stopped functioning.....
gst_nvcamera_open() failed ret=0
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in icvStartPipeline, file /home/nvidia/src/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp, line 450
File "trackgesture.py", line 387, in <module>
Main()
File "trackgesture.py", line 250, in Main
ret = cap.set(3,640)
cv2.error: /home/nvidia/src/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp:450: error: (-2) GStreamer: unable to start pipeline
in function icvStartPipeline
We can make our tensorflow with keras model run on the host but not on the TX2. We cannot fix this onboard camera issue. This is the terminal message.
General configuration for OpenCV 3.4.0 =====================================
Version control: unknown
Platform:
Timestamp: 2019-03-17T00:40:10Z
Host: Linux 4.4.38-tegra aarch64
CMake: 3.5.1
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: RELEASE
CPU/HW features:
Baseline: NEON FP16
required: NEON
disabled: VFPV3
C/C++:
Built as dynamic libs?: YES
C++ Compiler: /usr/bin/c++ (ver 5.4.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release):
Linker flags (Debug):
ccache: NO
Precompiled headers: YES
Extra dependencies: dl m pthread rt /usr/lib/aarch64-linux-gnu/libGLU.so /usr/lib/aarch64-linux-gnu/libGL.so cudart nppc nppial nppicc nppicom nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cufft -L/usr/local/cuda-9.0/lib64
3rdparty dependencies:
OpenCV modules:
To be built: calib3d core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev dnn features2d flann highgui imgcodecs imgproc ml objdetect photo python2 python3 python_bindings_generator shape stitching superres video videoio videostab
Disabled: js world
Disabled by dependency: -
Unavailable: java ts viz
Applications: apps
Documentation: NO
Non-free algorithms: NO
GUI:
QT: YES (ver 5.5.1)
QT OpenGL support: YES (Qt5::OpenGL 5.5.1)
GTK+: NO
OpenGL support: YES (/usr/lib/aarch64-linux-gnu/libGLU.so /usr/lib/aarch64-linux-gnu/libGL.so)
VTK support: NO
Media I/O:
ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.8)
JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver )
WEBP: build (ver encoder: 0x020e)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.2.54)
TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.6)
JPEG 2000: /usr/lib/aarch64-linux-gnu/libjasper.so (ver 1.900.1)
OpenEXR: build (ver 1.7.1)
Video I/O:
DC1394: YES (ver 2.2.4)
FFMPEG: YES
avcodec: YES (ver 56.60.100)
avformat: YES (ver 56.40.101)
avutil: YES (ver 54.31.100)
swscale: YES (ver 3.1.101)
avresample: NO
GStreamer:
base: YES (ver 1.8.3)
video: YES (ver 1.8.3)
app: YES (ver 1.8.3)
riff: YES (ver 1.8.3)
pbutils: YES (ver 1.8.3)
libv4l/libv4l2: 1.10.0 / 1.10.0
v4l/v4l2: linux/videodev2.h
gPhoto2: NO
Parallel framework: pthreads
Trace: YES (built-in)
Other third-party libraries:
Lapack: YES (/usr/lib/liblapack.so /usr/lib/libcblas.so /usr/lib/libatlas.so)
Eigen: YES (ver 3.2.92)
Custom HAL: YES (carotene (ver 0.0.1))
NVIDIA CUDA: YES (ver 9.0, CUFFT CUBLAS FAST_MATH)
NVIDIA GPU arch: 62
NVIDIA PTX archs:
OpenCL: YES (no extra features)
Include path: /home/nvidia/src/opencv-3.4.0/3rdparty/include/opencl/1.2
Link libraries: Dynamic load
Python 2:
Interpreter: /usr/bin/python2.7 (ver 2.7.12)
Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.12)
numpy: /usr/local/lib/python2.7/dist-packages/numpy/core/include (ver 1.16.2)
packages path: lib/python2.7/dist-packages
Python 3:
Interpreter: /usr/bin/python3 (ver 3.5.2)
Libraries: /usr/lib/aarch64-linux-gnu/libpython3.5m.so (ver 3.5.2)
numpy: /home/nvidia/.local/lib/python3.5/site-packages/numpy/core/include (ver 1.16.2)
packages path: lib/python3.5/dist-packages
Python (for build): /usr/bin/python2.7
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Matlab: NO
Install to: /usr/local
It looks like this error occurs when setting the resolution.
Could you try to remove this line and try it again?
cap.set(3,640)
