I want use the on board camera of the TX2 dev board for a gimbal student university project. But I have trouble to make it working properly. Any advice will be welcome :-)
I installed the JETPACK 4.2 on my TX2 successfully from a ubuntu Host with sdkmanager-0.9.13-4763-amd64.deb.
Then I wanted to install OpenCV 3.4.6
I Use different Tuto from
- Jetson Hack : https://www.jetsonhacks.com/2018/05/28/build-opencv-3-4-with-cuda-on-nvidia-jetson-tx2/
- JK Jung : https://jkjung-avt.github.io/opencv3-on-tx2/
Thank you very much, It was very helpful, unfortunately, none of this script worked directly… but at the end of the day, I think I succeeded to build openCv 3.4.6.
I perform a print(cv2.getBuildInformation())
here is the result :
General
configuration for OpenCV 3.4.6 =====================================
Version control: unknown
Platform:
Timestamp: 2019-08-04T19:05:44Z
Host: Linux 4.9.140-tegra aarch64
CMake: 3.10.2
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: RELEASE
CPU/HW features:
Baseline: NEON FP16
required: NEON
disabled: VFPV3
C/C++:
Built as dynamic libs?: YES
C++11: YES
C++ Compiler: /usr/bin/c++ (ver 7.4.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release): -Wl,--gc-sections
Linker flags (Debug): -Wl,--gc-sections
ccache: NO
Precompiled headers: YES
Extra dependencies: m pthread cudart_static -lpthread dl rt nppc nppial nppicc nppicom nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cufft -L/usr/local/cuda-10.0/lib64 -L/usr/lib/aarch64-linux-gnu
3rdparty dependencies:
OpenCV modules:
To be built: calib3d core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev dnn features2d flann highgui imgcodecs imgproc ml objdetect photo python2 python3 shape stitching superres video videoio videostab
Disabled: world
Disabled by dependency: -
Unavailable: java js ts viz
Applications: apps
Documentation: NO
Non-free algorithms: NO
GUI:
GTK+: YES (ver 3.22.30)
GThread : YES (ver 2.56.4)
GtkGlExt: NO
VTK support: NO
Media I/O:
ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
WEBP: build (ver encoder: 0x020e)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
JPEG 2000: build (ver 1.900.1)
OpenEXR: build (ver 1.7.1)
HDR: YES
SUNRASTER: YES
PXM: YES
Video I/O:
DC1394: YES (ver 2.2.5)
FFMPEG: YES
avcodec: YES (ver 57.107.100)
avformat: YES (ver 57.83.100)
avutil: YES (ver 55.78.100)
swscale: YES (ver 4.8.100)
avresample: NO
GStreamer:
base: YES (ver 1.14.4)
video: YES (ver 1.14.4)
app: YES (ver 1.14.4)
riff: YES (ver 1.14.4)
pbutils: YES (ver 1.14.4)
libv4l/libv4l2: 1.14.2 / 1.14.2
v4l/v4l2: linux/videodev2.h
Parallel framework: pthreads
Trace: YES (built-in)
Other third-party libraries:
Lapack: YES (/usr/lib/aarch64-linux-gnu/liblapack.so /usr/lib/aarch64-linux-gnu/libcblas.so /usr/lib/aarch64-linux-gnu/libatlas.so)
Eigen: YES (ver 3.3.4)
Custom HAL: YES (carotene (ver 0.0.1))
Protobuf: build (3.5.1)
NVIDIA CUDA: YES (ver 10.0, CUFFT CUBLAS)
NVIDIA GPU arch: 62
NVIDIA PTX archs:
OpenCL: YES (no extra features)
Include path: /home/gimbal/src/opencv-3.4.6/3rdparty/include/opencl/1.2
Link libraries: Dynamic load
Python 2:
Interpreter: /usr/bin/python2.7 (ver 2.7.15)
Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.15+)
numpy: /usr/local/lib/python2.7/dist-packages/numpy/core/include (ver 1.16.4)
install path: lib/python2.7/dist-packages/cv2/python-2.7
Python 3:
Interpreter: /usr/bin/python3 (ver 3.6.8)
Libraries: /usr/lib/aarch64-linux-gnu/libpython3.6m.so (ver 3.6.8)
numpy: /usr/lib/python3/dist-packages/numpy/core/include (ver 1.13.3)
install path: lib/python3.6/dist-packages/cv2/python-3.6
Python (for build): /usr/bin/python2.7
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Install to: /usr/local
OpenCV version: 3.4.6
Is OpenCV install was done properly ?
Then I try to use the onboard Camera on the TX2 dev board with this Python :
It’s not working on my setup…
I try to understand, but I need your light on.
When I try to run the cannyDetection.py, nothing happens, then when I force to stop the terminal, I get this error message :
(python:8510): GStreamer-CRITICAL **: 04:24:31.806:
Trying to dispose element capsfilter1, but it is in PAUSED instead of the NULL state.
You need to explicitly set elements to the NULL state before
dropping the final reference, to allow them to clean up.
This problem may also be caused by a refcounting bug in the
application or some element.
(python:8510): GStreamer-CRITICAL **: 04:24:31.807:
Trying to dispose element capsfilter0, but it is in PAUSED instead of the NULL state.
Trying to dispose element nvvconv0, but it is in PAUSED instead of the NULL state.
(python:8510): GStreamer-CRITICAL **: 04:24:31.808:
Trying to dispose element pipeline0, but it is in READY instead of the NULL state.
(python:8510): GStreamer-CRITICAL **: 04:24:31.809: gst_element_get_state: assertion 'GST_IS_ELEMENT (element)' failed
VIDEOIO ERROR: V4L: device nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)I420, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink: Unable to query number of channels
File "./cannyDetection.py", line 134, in <module>
video_capture=open_onboard_camera()
File "./cannyDetection.py", line 40, in open_onboard_camera
return cv2.VideoCapture("nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)I420, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink")
KeyboardInterrupt
It seems Gstreamer to be the problem, please could you confirm ?
Thank you very much
