How to restart nvargus-daemon? sudo systemctl restart nvargus-daemon.service won't work
My goal is to release cv::VideoCapture if the app crashed. The problem is that sudo systemctl restart nvargus-daemon.service do not fix the problem. cv::VideoCapture(0) still refuse to open. However, cv::VideoCapture(1) does open.
What I’ve tried:
  1. sudo systemctl restart nvargus-daemon.service
  2. run cv::VideoCapture(1), it works. But cv::VideoCapture(0) refuses to open.
python3 main.py -i 7
nvbuf_utils: Could not get EGL display connection
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4656 x 3496 FR = 10.000000 fps Duration = 100000000 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3840 x 2160 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 4656 H = 3496
   seconds to Run    = 0
   Frame Rate = 10.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: ERROR OCCURRED
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (1757) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module nvarguscamerasrc0 reported: CANCELLED
GST_ARGUS: Cleaning up
(Argus) Error Timeout:  (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (886) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
  File "main.py", line 42, in <module>
    camera = Camera(sensor_id=sensor_id)
  File "/home/werate-01/Arducam-IMX519/JetsonCamera.py", line 91, in __init__
    raise RuntimeError("Failed to open camera!")
RuntimeError: Failed to open camera!
(Argus) Error InvalidState: Argus client is exiting with 4 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
Reference: Started getting an "Argus" error when running camera script - #11 by Rob_Royce
Please try this:
Nodelet connection closed - #3 by DaneLLL
See if it works in this use-case.
This is the error before restarting nvargus-daemon.
   Camera index = 0
   Camera mode  = 0
   seconds to Run    = 0
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
Start grabbing
Press 0 to switch to cam0
Press 1 to switch to cam1
Press q to terminate
Press r to enable ROI window
Press p to predict
terminate called after throwing an instance of 'cv::Exception'
  what():  OpenCV(4.1.1) /home/nvidia/host/build_opencv/nv_opencv/modules/core/src/copy.cpp:254: error: (-215:Assertion failed) channels() == CV_MAT_CN(dtype) in function 'copyTo'
Aborted (core dumped)
This is after sudo service nvargus-daemon restart
   Camera index = 0
   Camera mode  = 0
   seconds to Run    = 0
Start grabbing
Press p to predict
Third attempt: the SSH crashed.
   Camera index = 0
   Camera mode  = 0
   seconds to Run    = 0
You may tell what are your cameras:
v4l2-ctl -d0 --list-formats-ext
v4l2-ctl -d1 --list-formats-ext
Try this:
# Wait for a few seconds with
sleep 3
# Launch a gstreamer pipeline to display assuming an X server is available (if running remotely with ssh use X11 forwarding ssh -X or ssh -Y);
gst-launch-1.0 -v nvarguscamerasrc ! nvvidconv ! queue ! xvimagesink
Does this work ?
