Good evening!
I`m trying to analyze videos on remote computers (Jetson Nano) without displays. All information from remote servers stores in one database on main server.
I use OpenCV (Python) to capture video from camera (Raspberry Pi camera V2).
Here is the code I use to capture video:
def get_jetson_gstreamer_source(capture_width=1280, capture_height=720, display_width=1280, display_height=720, framerate=60, flip_method=0):
return (
f'nvarguscamerasrc ! video/x-raw(memory:NVMM), ' +
f'width=(int){capture_width}, height=(int){capture_height}, ' +
f'format=(string)NV12, framerate=(fraction){framerate}/1 ! ' +
f'nvvidconv flip-method={flip_method} ! ' +
f'video/x-raw, width=(int){display_width}, height=(int){display_height}, format=(string)BGRx ! ' +
'videoconvert ! video/x-raw, format=(string)BGR ! appsink'
video_capture = cv2.VideoCapture(get_jetson_gstreamer_source(), cv2.CAP_GSTREAMER)
With HDMI display it works fine, but without I get an obvious error:
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
(python3:7460): Gtk-WARNING **: 23:27:19.966: cannot open display:
CONSUMER: Done Success
WARNING Argus: 5 client objects still exist during shutdown:
547503252248 (0x7f68003558)
547508048944 (0x7f680016b0)
547508049104 (0x7f68001750)
547508052880 (0x7f680018b0)
547508054176 (0x7f68003440)
I tried to replace appsink by fakesink as in the example here, but I got an error:
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (801) open OpenCV | GStreamer warning: cannot find appsink in manual pipeline
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
If i try this code from Terminal, it works fine:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12’ ! fakesink
It is from this branch.
But if I try it from Python:
def get_jetson_gstreamer_source():
return(
f'nvarguscamerasrc sensor-id=0 ! ' + f'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12 ' +' ! fakesink'
I got:
Help me, please. What should I do to analyze videos on many remote Jetson Nano computers without display?
Best regards, Andron
