**• Hardware Platform Jetson Nano
**• DeepStream Version 5.1
**• JetPack Version 4.5.1
**• TensorRT Version 7.1.3
I run:
gst-launch-1.0 -e nvarguscamerasrc sensor_id=0 num-buffers=300 ! "video/x-raw(memory:NVMM), width=(int)3246, height=(int)2464, format=(string)NV12, framerate=(fraction)21/1" ! nvvidconv flip-method=2 ! "video/x-raw(memory:NVMM), format=(string)NV12" ! omxh264enc ! qtmux ! filesink location=full_size.mkv
and gst-launch records video to a file from the Jetson Nano’s CSI camera. But I need to write my own Pipeline in C++, which will perform the same task. I did the following:
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include <unistd.h>
int main(int argc, char *argv[]) {
GstElement *pipeline, *source, *capsfilter_one, *nvvidconv, *capsfilter_two, *omxh264enc, *qtmux, *filesink, *sink, *fakesink;
GstStateChangeReturn ret;
/* Initialize GStreamer */
gst_init (&argc, &argv);
source = gst_element_factory_make("nvarguscamerasrc", "source");
capsfilter_one = gst_element_factory_make("capsfilter", "input-capsfilter");
nvvidconv = gst_element_factory_make("nvvidconv", "nvvidconv");
capsfilter_two = gst_element_factory_make("capsfilter", "osd-capsfilter");
omxh264enc = gst_element_factory_make("omxh264enc", "omxh264enc");
qtmux = gst_element_factory_make("qtmux", "qtmux");
filesink = gst_element_factory_make("filesink", "filesink");
pipeline = gst_pipeline_new ("dsdewarper-from-camera");
if (!pipeline || !source || !capsfilter_one || !nvvidconv || !capsfilter_two || !omxh264enc || !qtmux || !filesink) {
g_printerr ("Not all elements could be created.\n");
return -1;
/* Build the pipeline */
gst_bin_add_many (GST_BIN (pipeline), source, capsfilter_one, nvvidconv, capsfilter_two, omxh264enc, qtmux, filesink, NULL);
if (!gst_element_link_many (source, capsfilter_one, nvvidconv, capsfilter_two, omxh264enc, qtmux, filesink, NULL)) {
g_printerr("Elements could not be linked.\n");
gst_object_unref(pipeline);
return -1;
/* Modify the source's properties */
g_object_set(source, "sensor-id", 0, NULL);
g_object_set(source, "num-buffers", 300, NULL);
g_object_set(nvvidconv, "flip-method", 2, NULL);
g_object_set(filesink, "location", "cameracap.mkv", NULL);
GstCaps* const capsfilter_one_caps
gst_caps_new_simple("video/x-raw",
"width", G_TYPE_INT, 3264,
"height", G_TYPE_INT, 2464,
"framerate", GST_TYPE_FRACTION, 21, 1,
nullptr)
GstCapsFeatures* const memory_features { gst_caps_features_new("memory:NVMM", nullptr) };
gst_caps_set_features(capsfilter_one_caps, 0, memory_features);
g_object_set(capsfilter_one, "caps", capsfilter_one_caps, nullptr);
GstCaps* const capsfilter_two_caps { gst_caps_from_string("video/x-raw(memory:NVMM), format=(string)NV12") };
g_object_set(capsfilter_two, "caps", capsfilter_two_caps, nullptr);
/* Start playing */
ret = gst_element_set_state (pipeline, GST_STATE_PLAYING);
if (ret == GST_STATE_CHANGE_FAILURE) {
g_printerr ("Unable to set the pipeline to the playing state.\n");
gst_object_unref (pipeline);
return -1;
/* Free resources */
gst_element_set_state (pipeline, GST_STATE_NULL);
return 0;
I compile this code:
sudo gcc dsdwcamcap.cpp -o dsdwcamcap `pkg-config --cflags --libs gstreamer-1.0`
run:
sudo ./dsdwcamcap
and get this error:
(dsdwcamcap:12071): GStreamer-CRITICAL **: 19:19:39.577: gst_mini_object_set_qdata: assertion 'object != NULL' failed
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3264 H = 2464
seconds to Run = 0
Frame Rate = 21.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
GST_ARGUS: Cleaning up
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: Done Success
GST_ARGUS: Done Success
WARNING Argus: 2 client objects still exist during shutdown:
545527958304 (0x7f74001d18)
547502957504 (0x7f7c001880)
I can’t figure out what the mistake is. I am new to gstreamer, so probably some trivial error. I will be grateful if you can help.
