in-kernel printf
Hey, I want to use in-kernel printf.
I have cuda toolkit 3.2, VS 2008.
I have GTX 460.
I build my app for compute 2.0.
When I put printf(“helo”); in my kernel I get following compiler error:
: error: identifier “printf” is undefined
Why? Do I have to include some special header to use printf?
include stdio.h and it should work.
I compiled the code but now when I launch my kernel program crashes :( - why?
I build it on Realease config… should I use debug for printf or what?
It crashes on > program.exe!__tmainCRTStartup() Line 501 + 0xf bytes C
below is some strange file crtexe.c
            * do C++ constructors (initializers) specific to this EXE
            if (__native_startup_state == __initializing)
                _initterm( __xc_a, __xc_z ); // <<<<<<<<<<<<<<<<<<<<<<<<<<< this line unhandled exception
                __native_startup_state = __initialized;
Okay it works now, something strange happened and I had to recompile whole project…
Thanks a lot for help :)
mainCRTStartup is buried in the CUDA runtime library. A failure like that would generally suggest something in your build system, toolchain or CUDA toolkit is badly broken, but I can’t help with Windows or Visual Studio troubleshooting, sorry.
you can not use printf inside a kernel but there is an implementation called cuprintf.
yes you can. ignore my comment
External Image
I am having the same problem, and must be doing some boneheaded thing. I have compute capability 2.1, so I should be able to use printf. Here is my code:
include <stdio.h>
global void test_kernel() {
printf(“Can I do this?\n”);
} // end test_kernel
int main(int argc, char *arvc) {
test_kernel<<<1,1>>>();
I compile it with
nvcc -o hello_world hello_world.cu
And encounter the compilation error:
hello_world.cu(4): error: calling a host function from a device/global function is not allowed
Any help would be appreciated.
Pass an architecture selection option to nvcc to tell it you want to compile for a compute 2.1 device, something like
nvcc -arch=sm_21 -o hello_world hello_world.cu
Yeah!
I had to add the line
cudaThreadSynchronize();
after the kernel call, but now it is working.
Thank you very much.
