Problems with cudaMalloc(), on printf() just in the kernelcode
Hi friends
Men Env is:
WIN XP64
VC2008
More see below.
I wrote a kernel with a printf() in it.
I cudaMalloc() Device memory,
and get return code 10200,
0x0000000180034350 “unspecified driver error”
The kernel is not called yet from the hist code
or any other kernel.
If I remove the printf() from the
kernel, all is fine,
but i want to use printf()
in the kernel eventually.
Thank you in advance
Device 0: “GeForce GTX 460”
CUDA Driver Version: 3.20
CUDA Capability Major revision number: 2
CUDA Capability Minor revision number: 1
Total amount of global memory: 2147024896 bytes
Number of multiprocessors: 7
Number of cores: 224
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Clock rate: 1.40 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: Yes
Concurrent kernel execution: Yes
Device has ECC support enabled: No
Hi friends
Men Env is:
WIN XP64
VC2008
More see below.
Warp size: 32
Integrated: No
I solved the problem.
It was a driver problem.
I had 260.89,
I installed the lower 260.61 over it,
confirming the ‘outdated/overwrite?’ MSG-Boxes.
Then I installed 260.89
again, and it works,
the DOS-Command even
redirect to files.
Great.
Just reinstalling 260.89
did not help.
I had 260.89,
redirect to files.
Great.
did not help.
Surprised that the downgrade and re-install made it work again! Oops…
I have never known that prinf() can be used in the kernel?
May be cuPrintf() is just what you want.
