In nvosd element I am getting two objects while iteration even though only one object is detected by the detector
• DeepStream Version
• TensorRT Version
I am having one issue in the deep stream pipeline… whenever I am using a tracker in the pipeline at the nvosd element I am getting two objects while iteration even though only one object is there in the frame. If I remove the tracker from the pipeline this issue is not exist. pipeline is like this (detector–>tracker ----> secondary inference —> osd).
What is the secondary inference?
Could follow this blog post to verify the detector and tracker are working first?
https://medium.com/@paul.sw.lee/running-yolov4-on-deepstream-6-511125d93a6f
I am using the Facenet model in the secondary inference for extracting the face embeddings of the detected face in the frame.
Yeah, I will check the referred blog
Can you share several pictures to show your issue?
