NVTracker functionality
**• Hardware Platform (Jetson / GPU) GPU A100 **
**• DeepStream Version 6.4 **
• TensorRT Version
Let’s say we have 3 objects detected by detector in frame 0 and in frame 1 only 2 objects are detected by detector and 1 object is missed by the detector. In our pipeline we use detector followed by tracker,so we are expecting that tracker should have still have given us 3 objects in frame1 but it gives only 2.This issue is seen in 6.4 deepstream tracker. Please let me know how can this be overcome ?
Can you have a try with shadow tracking target data? Gst-nvtracker — DeepStream documentation 6.4 documentation
Thanks for helping us.We tried your suggestion and we probed the source pad of nvtracker in python like this
def tracker_probe(self,pad, info, u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print(“Unable to get GstBuffer”)
return
print(“in tracker probe”)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    batch_user_meta_list = batch_meta.batch_user_meta_list
    print("batch_user_meta_list",batch_user_meta_list)
    while batch_user_meta_list is not None:
        user_meta = pyds.NvDsUserMeta.cast(batch_user_meta_list.data)
        user_meta_base_meta = user_meta.base_meta
        print("hello",int(user_meta_base_meta.meta_type))
        if int(user_meta_base_meta.meta_type) == 19:
            user_meta_data = pyds.NvDsTargetMiscDataBatch.cast(user_meta.user_meta_data)
            ab =  pyds.NvDsTargetMiscDataStream.cast(user_meta_data.list)
But we get error when we run the above code in the last line . So can u help us in getting rect_params field available in NvDsTargetMiscDataFrame in python. Or do we need to use another method to get all the bbox of shadow tracks by probing tracker source pad.
You method is right. Maybe you need write python bindings for NvDsTargetMiscDataFrame.
