Find Embeddings from Infered Objects
• Hardware Platform (GPU): Currently debugging in GTX 1080
• DeepStream Version : 7.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only): 535.183.01
• CUDA Version: 12.2
• Issue Type: bugs
• How to reproduce the issue ?
Run Deepstream_test_2.py, attaching one. The l_user_meta is an empty array. I was trying to find embeddings from the tracker initially but that also failed.
deepstream-test2.zip (15.6 KB)
This was added as tracker_sink_pad = tracker.get_static_pad("sink")
tracker_sink_pad.add_probe(Gst.PadProbeType.BUFFER, tracker_sink_pad_buffer_probe, 0)
def tracker_sink_pad_buffer_probe(pad,info,u_data):
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        sys.stderr.write("Unable to get GstBuffer")
        return Gst.PadProbeReturn.OK
    #sys.stdout.write("Found GstBuffer in Tracker Sink\n")
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        #sys.stdout.write("Found l_frame in Tracker Sink\n")
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
            l_obj = frame_meta.obj_meta_list
            while l_obj is not None:
                #sys.stdout.write("Found l_obj in Tracker Sink\n")
                try:
                    obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                    l_user_meta = obj_meta.obj_user_meta_list
                    print(f"l_user_meta: {[a for a in dir(l_user_meta) if not a.startswith('__')]}")
                    while l_user_meta is not None:
                        try:
                            user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
                            if user_meta:
                                print(f"User meta type found {user_meta.base_meta.meta_type}\n")
                            l_user_meta = l_user_meta.next
                        except StopIteration:
                            break
                    l_obj = l_obj.next
                    break
            l_frame = l_frame.next
            break
tracker user meta is added in tracker plugin. please add probe function on tracker’s src or the plugins after tracker.
What do you mean by that? Is there another plugin which we need to build and add?
Also I do not see NVDS_TRACKER_OBJ_REID_META in pyds.NvDsMetaType. I built the bindings from the doc
def tracker_src_pad_buffer_probe(pad,info,u_data):
    if not gst_buffer:
        try:
            # it alone.
                try:
                        try:
                            if user_meta:
                            break
                    l_obj = l_obj.next
                    break
            break
Nothing gets printed in l_user_meta
I mean, the code should be corrected to tracker_sink_pad = tracker.get_static_pad(“src”) because the tracker 's meta will be added when exiting tracker plugin.
Yes, The change to "src" works.
But the nvDsMetaType is not known in python bindings.
For Deepstream7.0, Do I need to change the 3rd party git commit id?
Output is:
l_user_meta: ['data', 'next', 'prev']
User meta type found NvDsMetaType.???
python binding is opensource. you can add NVDS_TRACKER_OBJ_REID_META after referring to NVDS_TRACKER_PAST_FRAME_META adding code.
Hi @fanzh ,
Could you please review the PR: Add pyBindings for NVDS_TRACKER_OBJ_REID_META by amarflybot · Pull Request #12 · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
@amarendra.k.kumar
Thanks for your contribution, this PR has been merged to internal branch and will be publiched at next version.
