• Hardware Platform (Jetson / GPU) : Jetson AGX Orin 32GB
• DeepStream Version : 6.3
• JetPack Version (valid for Jetson only) : 5.1.2
• TensorRT Version : 8.5.2
Hii, Team Nvidia:
I am trying to run multi object detection and tracking on jetson in real time.
I know that sample code is provided that loads the video and does the object detection and tracking.(deepstream_python_apps/apps/deepstream-test2)
However, all I want to do in the deepstream is objects tracking, and object detection is done outside of the deepstream.
My approach is add obj_meta to the newly created gst-buffer and flow it into a pipeline that has nvtracking. As follows.
batch_meta = pyds.nvds_create_batch_meta(32)
frame_meta = pyds.nvds_acquire_frame_meta_from_pool(batch_meta)
detections = [ # Temporary detection results
(100, 100, 200, 200, 1, 0.9),
(150, 150, 250, 250, 2, 0.85)]
for detection in detections:
obj_meta = pyds.NvDsObjectMeta.cast(pyds.nvds_acquire_obj_meta_from_pool(batch_meta))
obj_meta.rect_params.left = detection[0]
obj_meta.rect_params.top = detection[1]
obj_meta.rect_params.width = detection[2]
obj_meta.rect_params.height = detection[3]
obj_meta.class_id = detection[4]
obj_meta.confidence = detection[5]
pyds.nvds_add_obj_meta_to_frame(frame_meta, obj_meta,None)
gst_buffer = Gst.Buffer.new_allocate(None, 1024, None)
batch_meta_buf = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer)) # error
My code gives me an error in batch_meta_buf = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer)).
Because the newly created gst-buffer does not have batch_meta.
Deepstream-python provides “gst_buffer_add_nvds_meta” as a function to add batch_meta to gst-buffer, however I face the same problem as https://forums.developer.nvidia.com/t/attaching-user-metadata-to-gstreamer-buffer-using-python-bindings/223486
Is what I am trying to do feasible?
