In the case of Yolov3-spp, how do I specify the model parameters?
Only Yolov3 and tiny Yolov3 are mentioned in the manual.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_custom_YOLO.html#
Thank you.
Sorry that Yolov3-spp is not officially supported by the Deepstream.
But suppose it has a similar configure setting as the YOLOv3 model.
To confirm this, you can check the details from the .cfg file directly.
When I run Yolov3, I get the following error.
How can I fix it?
NvDsInferStatus Yolo::buildYoloNetwork(std::vector&, nvinfer1::InetworkDefinition&): Assertion ‘0’ failed.
Thank you.
Do you have a more detailed log?
The source of buildYoloNetwork can be found in the below file:
/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.cpp
Could you help to check which assertion causes the error first?
