Inference fails on etlt model file
• Hardware is T4
• Network Type is Detectnet_v2, specifically trafficcamnet
Configuration of the TAO Toolkit Instance
dockers:
	nvidia/tao/tao-toolkit:
		4.0.0-tf2.9.1:
			docker_registry: nvcr.io
			tasks:
				1. classification_tf2
				2. efficientdet_tf2
		4.0.0-tf1.15.5:
			tasks:
				1. augment
				2. bpnet
				3. classification_tf1
				4. detectnet_v2
				5. dssd
				6. emotionnet
				7. efficientdet_tf1
				8. faster_rcnn
				9. fpenet
				10. gazenet
				11. gesturenet
				12. heartratenet
				13. lprnet
				14. mask_rcnn
				15. multitask_classification
				16. retinanet
				17. ssd
				18. unet
				19. yolo_v3
				20. yolo_v4
				21. yolo_v4_tiny
				22. converter
		4.0.1-tf1.15.5:
			tasks:
				1. mask_rcnn
				2. unet
		4.0.0-pyt:
			tasks:
				1. action_recognition
				2. deformable_detr
				3. segformer
				4. re_identification
				5. pointpillars
				6. pose_classification
				7. n_gram
				8. speech_to_text
				9. speech_to_text_citrinet
				10. speech_to_text_conformer
				11. spectro_gen
				12. vocoder
				13. text_classification
				14. question_answering
				15. token_classification
				16. intent_slot_classification
				17. punctuation_and_capitalization
format_version: 2.0
toolkit_version: 4.0.1
published_date: 03/06/2023
Inference Spec (just the inferencer_config part)
inferencer_config{
  # defining target class names for the experiment.
  # Note: This must be mentioned in order of the networks classes.
  target_classes: "car"
  target_classes: "bicycle"
  target_classes: "person"
  target_classes: "road_sign"
  # Inference dimensions.
  image_width: 960
  image_height: 544
  # Must match what the model was trained for.
  image_channels: 3
  batch_size: 1
  gpu_index: 0
  # model handler config
  tensorrt_config{
    etlt_model: "/workspace/tao-experiments/trafficcamnet/pretrained_pruned_v1.0.3/trafficcamnet_vpruned_v1.0.3/resnet18_trafficcamnet_pruned.etlt"
    save_engine: true
    trt_engine: "/workspace/tao-experiments/trafficcamnet/pretrained_pruned_v1.0.3/trafficcamnet_vpruned_v1.0.3/resnet18_trafficcamnet_pruned.etlt.trt"
    backend_data_type: FP32
when I run tao detectnet_v2 inference calling this spec file on a small set of images, I get the following error
2023-04-12 00:16:16,882 [INFO] root: Registry: ['nvcr.io']
2023-04-12 00:16:17,140 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
Using TensorFlow backend.
2023-04-12 00:16:24.756665: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
  RequestsDependencyWarning)
Matplotlib created a temporary config/cache directory at /tmp/matplotlib-t28tkc0v because the default path (/.config/matplotlib) is not a writable directory; it is highly recommended to set the MPLCONFIGDIR environment variable to a writable directory, in particular to speed up the import of Matplotlib and to better support multiprocessing.
INFO: Merging specification from /workspace/tao-experiments/trafficcamnet/specs/trafficcamnet_pruned_inference_kitti_etlt.txt
INFO: Overlain images will be saved in the output path.
INFO: Constructing inferencer
INFO: Engine file not found at /workspace/tao-experiments/trafficcamnet/pretrained_pruned_v1.0.3/trafficcamnet_vpruned_v1.0.3/resnet18_trafficcamnet_pruned.etlt.trt
INFO: Using TensorRT to optimize model and generate an engine.
[04/12/2023-00:16:39] [TRT] [W] CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See `CUDA_MODULE_LOADING` in https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#env-vars
INFO: Initializing int8 calibration table.
INFO: A valid tensorfile doesn't exist at None. The calibrator will attempt to read from a cache file if provided.
[04/12/2023-00:16:39] [TRT] [W] The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
  File "</usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/scripts/inference.py>", line 3, in <module>
  File "<frozen iva.detectnet_v2.scripts.inference>", line 210, in <module>
  File "<frozen iva.detectnet_v2.scripts.inference>", line 206, in main
  File "<frozen iva.detectnet_v2.scripts.inference>", line 117, in inference_wrapper_batch
  File "<frozen iva.detectnet_v2.inferencer.trt_inferencer>", line 345, in network_init
  File "<frozen iva.detectnet_v2.inferencer.trt_inferencer>", line 213, in _parse_caffe_model
  File "/usr/lib/python3.6/genericpath.py", line 30, in isfile
    st = os.stat(path)
TypeError: stat: path should be string, bytes, os.PathLike or integer, not NoneType
The error does not seem very informative, but when I use a “tlt_config” in the spec file, e.g. with the unpruned resnet18_trafficcamnet.tlt model, the inference works. Any suggestions?
Please add below inside tensorrt_config.
parser: ETLT
Thanks, that worked.
Is it possible to retrain an etlt model? Or to convert from etlt → tlt?
I ask because the pruned models for trafficcam work much better on my data than the unpruned model, but those are only available in etlt format.
Sorry, this is not working.
