• Hardware: JetsonTX2
• Network Type
- EmotionNet
- HeartRateNet
- GazeEstimation
• TLT Version: v3.21.11-tf1.15.5
• Jetpack 4.4
I have managed to convert gaze model, emotionNet and heartRateNet as well as face detection and facial landmarks from model.etlt to TensorRT engine .trt file.
After the conversion my idea was to use trt models with Python scripts. I have found a way to load/inference FaceDetect & FacialLandmarks and works pretty good.
I have continued to work with EmotionNet but I am still not sure about preprocessing of facial landmarks as input to that model. I tried to normalized them, but still seem to get all zeros out from the model.
I am interested if you have some useful scripts that preprocess the data into these TensorRT models (GazeNet, EmotionNet, HeartRateNet) as a inference script. I have found the Jupyter notebooks but there isn’t nothing that helps with understanding how the models actually expect the data.
Best regards.
Morganh
February 28, 2022, 12:53pm
#2
Currently, only below applications are available for reference.
At the moment I am approaching this using this python script. But still I get vector of zeros from inference on the tensor trt model.
import time
import itertools
import numpy as np
import pycuda.driver as cuda
import tensorrt as trt
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
class EmotionDetectNet(object):
def __init__(self, trt_path, batch_size=1):
self.trt_path = trt_path
self.batch_size = batch_size
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
trt_runtime = trt.Runtime(TRT_LOGGER)
self.trt_engine = self._load_engine(trt_runtime, self.trt_path)
self.inputs, self.outputs, self.bindings, self.stream = \
self._allocate_buffers()
self.context = self.trt_engine.create_execution_context()
self.list_output = None
def _load_engine(self, trt_runtime, engine_path):
with open(engine_path, "rb") as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
def _allocate_buffers(self):
inputs = []
outputs = []
bindings = []
stream = cuda.Stream()
binding_to_type = {
"input_landmarks:0": np.float32,
"softmax/Softmax:0": np.float32
for binding in self.trt_engine:
print("Binding: {}".format(binding))
print("Binding shape: {}".format(self.trt_engine.get_binding_shape(binding)))
size = trt.volume(self.trt_engine.get_binding_shape(binding)) \
* self.batch_size * -1
dtype = binding_to_type[str(binding)]
host_mem = cuda.pagelocked_empty(size, dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(device_mem))
if self.trt_engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
return inputs, outputs, bindings, stream
def _do_inference(self, context, bindings, inputs,
outputs, stream):
[cuda.memcpy_htod_async(inp.device, inp.host, stream) \
for inp in inputs]
context.execute_async(
batch_size=self.batch_size, bindings=bindings,
stream_handle=stream.handle)
[cuda.memcpy_dtoh_async(out.host, out.device, stream) \
for out in outputs]
stream.synchronize()
return [out.host for out in outputs]
def predict(self, facial_landmarks):
# List of landmarks per face
# Input landmarks are 80 tuple points, points after index 68 are the ones for eye pupil center, and we
# need only classical 68 facial landmarks points to estimate emotion
for landmarks in facial_landmarks:
input_landmarks = np.array(list(itertools.chain(*landmarks)))
# Take only first 68 tuple points (68,2) into (136,1) vector as input to the emotion model
input_landmarks = np.array(input_landmarks[0:136])
# Normalize to {0, 1} range
input_landmarks = (input_landmarks - np.min(input_landmarks)) / (np.max(input_landmarks) - np.min(input_landmarks))
np.copyto(self.inputs[0].host, input_landmarks.ravel())
t_time = 0
for i in range(1):
t1 = time.perf_counter()
emotion_class = self._do_inference(
self.context, bindings=self.bindings, inputs=self.inputs,
outputs=self.outputs, stream=self.stream)
t2 = time.perf_counter()
t_time += (t2 - t1)
print('Emotion detect inferece time:', t_time)
# Remove batch dimension
emotion_class = emotion_class[0]
# Emotion Class order:
# 0 - Neutral
# 1 - Happy
# 2 - Surprise
# 3 - Squint
# 4 - Disgust
# 5 - Scream
for e in emotion_class:
print("Emotion: {}".format(e))
return emotion_class
Morganh
February 28, 2022, 1:29pm
#4
Thank you for providing me with links.
I mean, I have a working example for face detection and facial landmarks, and I understand it is an classification network, but the output should be different than vector of zeros. At the moment I am feeding in values from Facial Landmark model (Facial Landmarks Estimation | NVIDIA NGC ) as input to Emotion Detection Model. I have also tried points in original coordinated inside the 80x80 face box and same points scaled to [0, 1] range. It seems that either of this approaches is not giving correct results.
Morganh
February 28, 2022, 2:23pm
#6
The input should be a face image. Could you try to run inference with “tao inference” firstly?
To check if your emotionnet tensorrt engine works.
https://docs.nvidia.com/tao/tao-toolkit/text/emotion_classification/emotion_classification.html#run-inference-on-the-model
system
closed
March 14, 2022, 2:24pm
#7
