Hi all,
After training a YOLO v4 model with TLT 3.0 and exporting it, I have some issue to perform inference using TensorRT in Python.
The model has been successfully trained, validated and tested in TLT 3.0. I could export the model and deploy it within a DeepStream 5 application.
Now I also need to deploy the model using TensorRT with the Python API. The first thing I did was to compile the TRT OSS to be able to use the BatchedNMS plugin required by the model.
I converted it using the tlt-converter utility (for CUDA 10.2, CUDNN 8 and TRT 7.1) using this command:
tlt-converter -k nvidia_tlt \
-d 3,768,1024 \
-o BatchedNMS \
-e model_fp32.engine \
-m 1 \
-t fp32 \
-i nchw \
yolov4.etlt
(You can download an etlt model file here: Dropbox - Error - Simplify your life. The model is trained to detect 15 classes. )
I wrote a piece of code to
- deserialize the TRT engine file that was created by the DeepStream application from the etlt file exported from TLT.
- load and pre-process the data
- copy the data to the gpu
- perform the inference
- get the data back from the gpu
I could manage to get the code run without errors, but the output of the inference does not seem right.
There are 4 outputs, as expected:
- number of detections (single int)
- the bounding box coordinates (array)
- the scores of each object
- the class labels.
But, even when the number of detection is > 0, the bounding box of coordinates returns an array filled with 0. That’s the same issue for the scores and class labels: arrays filled with only 0.
In the PGIE configuration file used by the DeepStream app (that runs as expected) there are some properties related to the input of the model, such as the offsets, the colour format and the input dimension:
[property]
offsets=103.939;116.779;123.68
net-scale-factor=1
#0=RGB, 1=BGR
model-color-format=1
infer-dims=3;768;1024
batch-size=1
num-detected-classes=15
I have applied those in the code I developed as you can see in the snippet
below:
import tensorrt as trt
TRT_LOGGER = trt.Logger(trt.Logger.VERBOSE)
trt.init_libnvinfer_plugins(TRT_LOGGER,'')
DTYPE_TRT = trt.float32
import pycuda.driver as cuda
import pycuda.autoinit
from PIL import Image
import numpy as np
path_img = "image.jpg"
offsets = ( 103.939, 116.779, 123.68 )
yolo_reso = (3, 768, 1024)
# Simple helper data class that's a little nicer to use than a 2-tuple
# from TRT Python sample code
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
def allocate_buffers(engine):
inputs = []
outputs = []
bindings = []
for binding in engine:
size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
dtype = trt.nptype(engine.get_binding_dtype(binding))
#dtype = DTYPE_TRT
print(dtype)
# Allocate host and device buffers
host_mem = cuda.pagelocked_empty(size, dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
# Append the device buffer to device bindings.
bindings.append(int(device_mem))
# Append to the appropriate list.
if engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
return inputs, outputs, bindings
def load_input(img_path, host_buffer):
# convert to BGR and CHW format
with Image.open(img_path) as img:
# RGB to BGR
r, g, b = img.split()
img = Image.merge('RGB', (b, g, r))
c, h, w = yolo_reso
dtype = trt.nptype(DTYPE_TRT)
img_res = img.resize((w, h), Image.BICUBIC)
img_res = np.array(img_res, dtype=dtype, order='C')
# HWC to CHW format:
img_chw = np.transpose(img_res, [2, 0, 1])
# Applying offsets to BGR channels
img_chw[0] = img_chw[0] - offsets[0]
img_chw[1] = img_chw[1] - offsets[1]
img_chw[2] = img_chw[2] - offsets[2]
img_array = img_chw.ravel()
np.copyto(host_buffer, img_array)
# Inference
with open("model_fp32.engine", "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
engine = runtime.deserialize_cuda_engine(f.read())
with engine.create_execution_context() as context:
# allocate buffers
inputs, outputs, bindings = allocate_buffers(engine)
stream = cuda.Stream()
# load image and pre-processing
load_input(path_img, inputs[0].host)
# transfer input data to the GPU.
cuda.memcpy_htod_async(inputs[0].device, inputs[0].host, stream)
# inference
inference = context.execute_async(batch_size=1, bindings=bindings, stream_handle=stream.handle)
# Transfer predictions back from the GPU.
cuda.memcpy_dtoh_async(outputs[0].host, outputs[0].device, stream)
# Synchronize the stream
stream.synchronize()
# Print the host output:
print("OUTPUT")
print(outputs)
A sample output of the code is given below:
OUTPUT
[Host:
[42]
Device:
<pycuda._driver.DeviceAllocation object at 0x7f707366e3a0>, Host:
[0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.
0. 0. 0. 0. 0. 0. 0. 0.]
Device:
<pycuda._driver.DeviceAllocation object at 0x7f707366e490>, Host:
Device:
<pycuda._driver.DeviceAllocation object at 0x7f707366e580>, Host:
Device:
<pycuda._driver.DeviceAllocation object at 0x7f707366e670>]
I have tested different images and always get the same type of output. Any idea why I only get 0 (also the size of the 3 array is always the same)?
I am wondering if my issue is related to the pre-processing of the data? Or am I missing something else for the inference?
I tried different type of pre-processing (with and without the offsets, BGR and RGB format, dividing the pixel values by 255…) and I always get the same type of output (only the number of detection varies).
Also, it is not very clear from the DeepStream documentation, but does the offsets apply to the BGR channels or the RGB channels? I.e. should the first component of the offsets apply to the R channel of the B channel of the input image?
Please note that when I use the etlt or TensorRT engine file in DeepStream, it works without any issue. But unfortunately I cannot use DeepStream for this work.
Thanks,
Johan
(PS: I have already asked that question in the TensorRT forum, but was redirected here - YOLO v4 inference with TensorRT after training with TLT 3.0 - #4 by johan_b)
Environment
TensorRT Version: 7.1.3
GPU Type: Titan V
Nvidia Driver Version: 455.45.01
CUDA Version: 10.2
CUDNN Version: 8
Operating System + Version: Ubuntu 18.04 LTS
Python Version (if applicable): 3.6.9
Baremetal or Container (if container which image + tag): Baremetal
