I have trained a detectnet_v2 model and then converted it to .trt engine… I am able to infer it using tlt-infer inside the docker. But how can i use this .trt file outside the docker in my own python application ?
Hi @Morganh,
Thanks, it worked for detectnet_v2 made .trt file inference. But now i created a .engine file using yolo. And i am getting the following error. I am running it inside the container itself with my code.
[TensorRT] ERROR: INVALID_ARGUMENT: getPluginCreator could not find plugin BatchTilePlugin_TRT version 1
[TensorRT] ERROR: safeDeserializationUtils.cpp (293) - Serialization Error in load: 0 (Cannot deserialize plugin since corresponding IPluginCreator not found in Plugin Registry)
[TensorRT] ERROR: INVALID_STATE: std::exception
[TensorRT] ERROR: INVALID_CONFIG: Deserialize the cuda engine failed.
File "main.py", line 36, in <module>
context = trt_engine.create_execution_context()
AttributeError: 'NoneType' object has no attribute 'create_execution_context'
root@605c1edbf876:/workspace/tlt-experiments/box_jeston#
could you please help me if you have a solution?
Thanks…
Should i build TensorRT OSS inside the container ? i read these plugins are required for yolov3, batchTilePlugin, resizeNearestPlugin and batchedNMSPlugin. But can i build TensorRT OSS inside nvidia tlt container ?
Please refer to github https://github.com/NVIDIA-AI-IOT/deepstream_tlt_apps mentioned in https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/text/deploying_to_deepstream.html#generating-an-engine-using-tlt-converter
This is ONLY needed when running SSD , DSSD , RetinaNet , YOLOV3 and MaskRCNN models because some TRT plugins such as BatchTilePlugin required by these models is not supported by TensorRT7.x native package.
Moving this topic into TLT forum.
Yes. I saw that. " TensorRT OSS on x86"… But i want to run the code inside the nvidia tlt container itself. Is it possible to build TensorRT OSS inside the container?
And inside the nvidia tlt container tensorrt version is 7.0.0.11, should i downgrade it for batchTilePlugin to support?
See Invalid device function error when export .tlt file to .etlt , it is possible to build OSS inside the docker.
git clone -b release/7.0 https://github.com/nvidia/TensorRT TensorRT && \
Thank you so much… And how i can determine DGPU_ARCHS variable for my GPU? My GPU is GeForce GTX 1660 Ti/PCIe/SSE2
I was not able to get it from deviceQuery.cpp.
This is my nividia-smi output,
| NVIDIA-SMI 440.100 Driver Version: 440.100 CUDA Version: 10.2 |
| 0 GeForce GTX 166... Off | 00000000:01:00.0 On | N/A |
| N/A 49C P8 8W / N/A | 1159MiB / 5941MiB | 32% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
Reference:
Your card 's compute capability is 7.5 . Please set GPU_ARCHS to 75.
Thanks @Morganh… I did the full steps you mentioned to for Installing TRT OSS to the base docker. But still the same error remains. After installing TRT OSS, it should get those required plugins right? But still “could not find plugin BatchTilePlugin_TRT version 1” error is there…
Have you replaced the plugin “libnvinfer_plugin.so*”?
See more in https://github.com/NVIDIA-AI-IOT/deepstream_tlt_apps/tree/master/TRT-OSS/Jetson
Yes i did these steps,
cp out/libnvinfer_plugin.so.7.0.0.1 /usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so.7.0.0 && \
cp out/libnvinfer_plugin_static.a /usr/lib/x86_64-linux-gnu/libnvinfer_plugin_static.a && \
cd ../../../ && \
rm -rf trt_oss_src
Can you share below result?
$ ll -sh /usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so*
Please take a look at my comment shared in below topic.
this is the output for ll -sh /usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so*,
0 lrwxrwxrwx 1 root root 26 Dec 17 2019 /usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so -> libnvinfer_plugin.so.7.0.0
0 lrwxrwxrwx 1 root root 26 Dec 17 2019 /usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so.7 -> libnvinfer_plugin.so.7.0.0
4.1M -rw-r--r-- 1 root root 4.1M Jan 13 16:47 /usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so.7.0.0
Please check my comment in above link.
Please see below.
Please follow the exact step shared in the github.
Original:
$ ll -sh /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so*
0 lrwxrwxrwx 1 root root 26 Apr 26 16:41 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so -> libnvinfer_plugin.so.7.1.0
0 lrwxrwxrwx 1 root root 26 Apr 26 16:41 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7 -> libnvinfer_plugin.so.7.1.0
4.5M -rw-r–r-- 1 root root 4.5M Apr 26 16:38 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.0If
$ sudo mv /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.0 ~/libnvinfer_plugin.so.7.1.0.bak
$ sudo cp {TRT_SOURCE}/build/out/libnvinfer_plugin.so.7.0.0.1 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.0
$ sudo ldconfig
then
nvidia@nvidia:~$ ll /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so*
lrwxrwxrwx 1 root root 26 Apr 27 08:53 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so -> libnvinfer_plugin.so.7.1.0*
lrwxrwxrwx 1 root root 26 Apr 27 08:53 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7 -> libnvinfer_plugin.so.7.1.0*
lrwxrwxrwx 1 root root 26 Apr 27 08:55 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.0.0 -> libnvinfer_plugin.so.7.1.0*
-rwxr-xr-x 1 root root 4652648 Apr 27 08:55 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.0*That’s the expected now.
