On giving this command make nvinfer_plugin -j$(nproc) i could see two warnings. Apart from that installation was successful, and inside build/out folder, libnvinfer_plugin.so, libnvinfer_plugin.so.7.0.0 , libnvinfer_plugin.so.7.0.0.1 these files got generated.
these are the final few lines of the log,
/workspace/TensorRT/plugin/multilevelProposeROI/multilevelProposeROIPlugin.cpp: In member function ‘virtual int nvinfer1::plugin::MultilevelProposeROI::enqueue(int, const void* const*, void**, void*, cudaStream_t)’:
/workspace/TensorRT/plugin/multilevelProposeROI/multilevelProposeROIPlugin.cpp:408:46: warning: pointer of type ‘void *’ used in arithmetic [-Wpointer-arith]
mParam, proposal_ws, workspace + kernel_workspace_offset,
/workspace/TensorRT/plugin/multilevelProposeROI/multilevelProposeROIPlugin.cpp:425:29: warning: pointer of type ‘void *’ used in arithmetic [-Wpointer-arith]
[ 60%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/detectionForward.cu.o
[ 60%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/extractFgScores.cu.o
[ 60%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/gatherTopDetections.cu.o
[ 66%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/generateAnchors.cu.o
[ 66%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/gridAnchorLayer.cu.o
[ 66%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/maskRCNNKernels.cu.o
[ 73%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/nmsLayer.cu.o
[ 73%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/normalizeLayer.cu.o
[ 73%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/permuteData.cu.o
[ 73%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/priorBoxLayer.cu.o
[ 80%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/proposalKernel.cu.o
[ 80%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/proposalsForward.cu.o
[ 80%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/regionForward.cu.o
[ 86%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/reorgForward.cu.o
[ 86%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/roiPooling.cu.o
[ 86%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/rproiInferenceFused.cu.o
/workspace/TensorRT/plugin/common/kernels/proposalKernel.cu(34): warning: variable "ALIGNMENT" was declared but never referenced
[ 93%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/cudaDriverWrapper.cu.o
[ 93%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/sortScoresPerImage.cu.o
[ 93%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/sortScoresPerClass.cu.o
[ 93%] Building CXX object plugin/CMakeFiles/nvinfer_plugin.dir/InferPlugin.cpp.o
[100%] Building CXX object plugin/CMakeFiles/nvinfer_plugin.dir/__/samples/common/logger.cpp.o
[100%] Linking CUDA device code CMakeFiles/nvinfer_plugin.dir/cmake_device_link.o
[100%] Linking CXX shared library ../out/libnvinfer_plugin.so
[100%] Built target nvinfer_plugin
After this succesfully copied libnvinfer_plugin.so.7.0.0.1 file inside build/out folder to, usr/lib/x86_64-linux-gnu/ folder in the name libnvinfer_plugin.so.7.0.0
and still sudo ldconfig is not returning any output and while inferring, getPluginCreator could not find plugin BatchTilePlugin_TRT version 1 error is there
