Infiniband communication hangs when trying to use DirectRDMA
I’m trying to connect 2 GPU nodes over infiniband with Direct RDMA, but it works only with Direct RDMA disabled, if I try enabling it, the script hangs after initialization:
import torch
import torch.distributed as dist
dist.init_process_group(backend="nccl")
local_rank = dist.get_rank() % torch.cuda.device_count()
torch.cuda.set_device(local_rank)
data = torch.FloatTensor([1,] * 128).to("cuda")
dist.all_reduce(data, op=dist.ReduceOp.SUM)
torch.cuda.synchronize()
value = data.mean().item()
world_size = dist.get_world_size()
assert value == world_size, f"Expected {world_size}, got {value}"
print("PyTorch NCCL is successful!")
Here are the logs:
oot@gh-3714u06:/sgl-workspace# NCCL_NET_GDR_LEVEL=0 NCCL_DEBUG=INFO torchrun --nnodes=2 --nproc-per-node=1 --node_rank=0 --rdzv_backend=static --rdzv_endpoint=10.1.32.3:29400 test.py
gh-3714u06:4052:4052 [0] NCCL INFO Bootstrap : Using ib0.0065:10.1.32.3<0>
gh-3714u06:4052:4052 [0] NCCL INFO cudaDriverVersion 12040
NCCL version 2.21.5+cuda12.4
gh-3714u06:4052:4052 [0] NCCL INFO Comm config Blocking set to 1
gh-3714u06:4052:4122 [0] NCCL INFO Plugin Path : /opt/hpcx/nccl_rdma_sharp_plugin/lib/libnccl-net.so
gh-3714u06:4052:4122 [0] NCCL INFO P2P plugin IBext_v8
gh-3714u06:4052:4122 [0] NCCL INFO NET/IB : Using [0]mlx5_0:1/IB/SHARP [1]mlx5_1:1/IB/SHARP [2]mlx5_4:1/IB/SHARP [3]mlx5_5:1/IB/SHARP [4]mlx5_2:1/RoCE [RO]; OOB ib0.0065:10.1.32.3<0>
gh-3714u06:4052:4122 [0] NCCL INFO Using non-device net plugin version 0
gh-3714u06:4052:4122 [0] NCCL INFO Using network IBext_v8
gh-3714u06:4052:4122 [0] NCCL INFO ncclCommInitRank comm 0x55de8ca60500 rank 0 nranks 2 cudaDev 0 nvmlDev 0 busId 19000 commId 0x8056544fe7821b76 - Init START
gh-3714u06:4052:4122 [0] NCCL INFO NCCL_NET_GDR_LEVEL set by environment to LOC
gh-3714u06:4052:4122 [0] NCCL INFO Setting affinity for GPU 0 to ffffffff,00000000,ffffffff
gh-3714u06:4052:4122 [0] NCCL INFO comm 0x55de8ca60500 rank 0 nRanks 2 nNodes 2 localRanks 1 localRank 0 MNNVL 0
gh-3714u06:4052:4122 [0] NCCL INFO Channel 00/04 :    0   1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 01/04 :    0   1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 02/04 :    0   1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 03/04 :    0   1
gh-3714u06:4052:4122 [0] NCCL INFO Trees [0] 1/-1/-1->0->-1 [1] 1/-1/-1->0->-1 [2] -1/-1/-1->0->1 [3] -1/-1/-1->0->1
gh-3714u06:4052:4122 [0] NCCL INFO P2P Chunksize set to 131072
gh-3714u06:4052:4122 [0] NCCL INFO Channel 00/0 : 1[1] -> 0[0] [receive] via NET/IBext_v8/1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 01/0 : 1[1] -> 0[0] [receive] via NET/IBext_v8/1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 02/0 : 1[1] -> 0[0] [receive] via NET/IBext_v8/1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 03/0 : 1[1] -> 0[0] [receive] via NET/IBext_v8/1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 00/0 : 0[0] -> 1[1] [send] via NET/IBext_v8/1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 01/0 : 0[0] -> 1[1] [send] via NET/IBext_v8/1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 02/0 : 0[0] -> 1[1] [send] via NET/IBext_v8/1
gh-3714u06:4052:4122 [0] NCCL INFO Channel 03/0 : 0[0] -> 1[1] [send] via NET/IBext_v8/1
gh-3714u06:4052:4122 [0] NCCL INFO Connected all rings
gh-3714u06:4052:4122 [0] NCCL INFO Connected all trees
gh-3714u06:4052:4122 [0] NCCL INFO threadThresholds 8/8/64 | 16/8/64 | 512 | 512
gh-3714u06:4052:4122 [0] NCCL INFO 4 coll channels, 4 collnet channels, 0 nvls channels, 4 p2p channels, 2 p2p channels per peer
gh-3714u06:4052:4122 [0] NCCL INFO TUNER/Plugin: Failed to find ncclTunerPlugin_v2, using internal tuner instead.
gh-3714u06:4052:4122 [0] NCCL INFO ncclCommInitRank comm 0x55de8ca60500 rank 0 nranks 2 cudaDev 0 nvmlDev 0 busId 19000 commId 0x8056544fe7821b76 - Init COMPLETE
[rank0]:[W605 14:45:35.666511672 ProcessGroupNCCL.cpp:1496] Warning: WARNING: destroy_process_group() was not called before program exit, which can leak resources. For more info, please see https://pytorch.org/docs/stable/distributed.html#shutdown (function operator())
gh-3714u06:4052:4128 [0] NCCL INFO [Service thread] Connection closed by localRank 0
gh-3714u06:4052:4131 [0] NCCL INFO comm 0x55de8ca60500 rank 0 nranks 2 cudaDev 0 busId 19000 - Abort COMPLETE
root@gh-3714u06:/sgl-workspace# NCCL_DEBUG=INFO torchrun --nnodes=2 --nproc-per-node=1 --node_rank=0 --rdzv_backend=static --rdzv_endpoint=10.1.32.3:29400 test.py
gh-3714u06:4197:4197 [0] NCCL INFO Bootstrap : Using ib0.0065:10.1.32.3<0>
gh-3714u06:4197:4197 [0] NCCL INFO cudaDriverVersion 12040
gh-3714u06:4197:4197 [0] NCCL INFO Comm config Blocking set to 1
gh-3714u06:4197:4267 [0] NCCL INFO Plugin Path : /opt/hpcx/nccl_rdma_sharp_plugin/lib/libnccl-net.so
gh-3714u06:4197:4267 [0] NCCL INFO P2P plugin IBext_v8
gh-3714u06:4197:4267 [0] NCCL INFO NET/IB : Using [0]mlx5_0:1/IB/SHARP [1]mlx5_1:1/IB/SHARP [2]mlx5_4:1/IB/SHARP [3]mlx5_5:1/IB/SHARP [4]mlx5_2:1/RoCE [RO]; OOB ib0.0065:10.1.32.3<0>
gh-3714u06:4197:4267 [0] NCCL INFO Using non-device net plugin version 0
gh-3714u06:4197:4267 [0] NCCL INFO Using network IBext_v8
gh-3714u06:4197:4267 [0] NCCL INFO ncclCommInitRank comm 0x5594b5eb16a0 rank 0 nranks 2 cudaDev 0 nvmlDev 0 busId 19000 commId 0xb458bb774b113b3a - Init START
gh-3714u06:4197:4267 [0] NCCL INFO Setting affinity for GPU 0 to ffffffff,00000000,ffffffff
gh-3714u06:4197:4267 [0] NCCL INFO comm 0x5594b5eb16a0 rank 0 nRanks 2 nNodes 2 localRanks 1 localRank 0 MNNVL 0
gh-3714u06:4197:4267 [0] NCCL INFO Channel 00/04 :    0   1
gh-3714u06:4197:4267 [0] NCCL INFO Channel 01/04 :    0   1
gh-3714u06:4197:4267 [0] NCCL INFO Channel 02/04 :    0   1
gh-3714u06:4197:4267 [0] NCCL INFO Channel 03/04 :    0   1
gh-3714u06:4197:4267 [0] NCCL INFO Trees [0] 1/-1/-1->0->-1 [1] 1/-1/-1->0->-1 [2] -1/-1/-1->0->1 [3] -1/-1/-1->0->1
gh-3714u06:4197:4267 [0] NCCL INFO P2P Chunksize set to 131072
gh-3714u06:4197:4267 [0] NCCL INFO Channel 00/0 : 1[1] -> 0[0] [receive] via NET/IBext_v8/0/GDRDMA
gh-3714u06:4197:4267 [0] NCCL INFO Channel 01/0 : 1[1] -> 0[0] [receive] via NET/IBext_v8/0/GDRDMA
gh-3714u06:4197:4267 [0] NCCL INFO Channel 02/0 : 1[1] -> 0[0] [receive] via NET/IBext_v8/0/GDRDMA
gh-3714u06:4197:4267 [0] NCCL INFO Channel 03/0 : 1[1] -> 0[0] [receive] via NET/IBext_v8/0/GDRDMA
gh-3714u06:4197:4267 [0] NCCL INFO Channel 00/0 : 0[0] -> 1[1] [send] via NET/IBext_v8/0/GDRDMA
gh-3714u06:4197:4267 [0] NCCL INFO Channel 01/0 : 0[0] -> 1[1] [send] via NET/IBext_v8/0/GDRDMA
gh-3714u06:4197:4267 [0] NCCL INFO Channel 02/0 : 0[0] -> 1[1] [send] via NET/IBext_v8/0/GDRDMA
gh-3714u06:4197:4267 [0] NCCL INFO Channel 03/0 : 0[0] -> 1[1] [send] via NET/IBext_v8/0/GDRDMA
gh-3714u06:4197:4267 [0] NCCL INFO Connected all rings
gh-3714u06:4197:4267 [0] NCCL INFO Connected all trees
gh-3714u06:4197:4267 [0] NCCL INFO threadThresholds 8/8/64 | 16/8/64 | 512 | 512
gh-3714u06:4197:4267 [0] NCCL INFO 4 coll channels, 4 collnet channels, 0 nvls channels, 4 p2p channels, 2 p2p channels per peer
gh-3714u06:4197:4267 [0] NCCL INFO TUNER/Plugin: Failed to find ncclTunerPlugin_v2, using internal tuner instead.
gh-3714u06:4197:4267 [0] NCCL INFO ncclCommInitRank comm 0x5594b5eb16a0 rank 0 nranks 2 cudaDev 0 nvmlDev 0 busId 19000 commId 0xb458bb774b113b3a - Init COMPLETE
And some useful info:
Node 0:
(base) [szymon.ozog@gh-3714u06 ~]$ lsmod | grep nvidia
nvidia_uvm           1523712  0
nvidia_drm             73728  0
nvidia_modeset       1306624  1 nvidia_drm
nvidia_peermem         16384  0
nvidia              56598528  147 nvidia_uvm,nvidia_peermem,gdrdrv,nvidia_modeset
drm_kms_helper        167936  7 drm_vram_helper,ast,drm_display_helper,nvidia_drm,nouveau
ib_core               442368  9 rdma_cm,ib_ipoib,nvidia_peermem,iw_cm,ib_umad,rdma_ucm,ib_uverbs,mlx5_ib,ib_cm
drm                   577536  10 drm_kms_helper,drm_vram_helper,ast,drm_display_helper,nvidia,drm_ttm_helper,nvidia_drm,ttm,nouveau
(base) [szymon.ozog@gh-3714u06 ~]$ nvidia-smi topo -m
        GPU0    GPU1    GPU2    GPU3    GPU4    GPU5    GPU6    GPU7    NIC0    NIC1    NIC2    NIC3    NIC4    NIC5    CPU Affinity    NUMA Affinity   GPU NUMA ID
GPU0     X      NV18    NV18    NV18    NV18    NV18    NV18    NV18    PIX     NODE    NODE    NODE    SYS     SYS     0-31,64-95      0               N/A
GPU1    NV18     X      NV18    NV18    NV18    NV18    NV18    NV18    NODE    NODE    NODE    NODE    SYS     SYS     0-31,64-95      0               N/A
GPU2    NV18    NV18     X      NV18    NV18    NV18    NV18    NV18    NODE    PIX     NODE    NODE    SYS     SYS     0-31,64-95      0               N/A
GPU3    NV18    NV18    NV18     X      NV18    NV18    NV18    NV18    NODE    NODE    NODE    NODE    SYS     SYS     0-31,64-95      0               N/A
GPU4    NV18    NV18    NV18    NV18     X      NV18    NV18    NV18    SYS     SYS     SYS     SYS     PIX     NODE    32-63,96-127    1               N/A
GPU5    NV18    NV18    NV18    NV18    NV18     X      NV18    NV18    SYS     SYS     SYS     SYS     NODE    NODE    32-63,96-127    1               N/A
GPU6    NV18    NV18    NV18    NV18    NV18    NV18     X      NV18    SYS     SYS     SYS     SYS     NODE    PIX     32-63,96-127    1               N/A
GPU7    NV18    NV18    NV18    NV18    NV18    NV18    NV18     X      SYS     SYS     SYS     SYS     NODE    NODE    32-63,96-127    1               N/A
NIC0    PIX     NODE    NODE    NODE    SYS     SYS     SYS     SYS      X      NODE    NODE    NODE    SYS     SYS
NIC1    NODE    NODE    PIX     NODE    SYS     SYS     SYS     SYS     NODE     X      NODE    NODE    SYS     SYS
NIC2    NODE    NODE    NODE    NODE    SYS     SYS     SYS     SYS     NODE    NODE     X      PIX     SYS     SYS
NIC3    NODE    NODE    NODE    NODE    SYS     SYS     SYS     SYS     NODE    NODE    PIX      X      SYS     SYS
NIC4    SYS     SYS     SYS     SYS     PIX     NODE    NODE    NODE    SYS     SYS     SYS     SYS      X      NODE
NIC5    SYS     SYS     SYS     SYS     NODE    NODE    PIX     NODE    SYS     SYS     SYS     SYS     NODE     X
Legend:
  X    = Self
  SYS  = Connection traversing PCIe as well as the SMP interconnect between NUMA nodes (e.g., QPI/UPI)
  NODE = Connection traversing PCIe as well as the interconnect between PCIe Host Bridges within a NUMA node
  PHB  = Connection traversing PCIe as well as a PCIe Host Bridge (typically the CPU)
  PXB  = Connection traversing multiple PCIe bridges (without traversing the PCIe Host Bridge)
  PIX  = Connection traversing at most a single PCIe bridge
  NV#  = Connection traversing a bonded set of # NVLinks
NIC Legend:
  NIC0: mlx5_0
  NIC1: mlx5_1
  NIC2: mlx5_2
  NIC3: mlx5_3
  NIC4: mlx5_4
  NIC5: mlx5_5
(base) [szymon.ozog@gh-3714u06 ~]$ ibstat
CA 'mlx5_0'
        CA type: MT4129
        Number of ports: 1
        Firmware version: 28.41.1000
        Hardware version: 0
        Node GUID: 0x9c63c003005548fe
        System image GUID: 0x9c63c003005548fe
        Port 1:
                State: Active
                Physical state: LinkUp
                Rate: 400
                Base lid: 975
                LMC: 0
                SM lid: 359
                Capability mask: 0xa751e848
                Port GUID: 0x9c63c003005548fe
                Link layer: InfiniBand
CA 'mlx5_1'
        CA type: MT4129
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x9c63c003005548b6
        System image GUID: 0x9c63c003005548b6
        Port 1:
                State: Active
                Rate: 400
                Base lid: 976
                LMC: 0
                SM lid: 359
                Port GUID: 0x9c63c003005548b6
CA 'mlx5_2'
        CA type: MT4123
        Number of ports: 1
        Firmware version: 20.38.1900
        Hardware version: 0
        Node GUID: 0xb83fd2030091eb2a
        System image GUID: 0xb83fd2030091eb2a
        Port 1:
                State: Active
                Rate: 100
                Base lid: 0
                LMC: 0
                SM lid: 0
                Capability mask: 0x00010000
                Port GUID: 0xba3fd2fffe91eb2a
                Link layer: Ethernet
CA 'mlx5_3'
        CA type: MT4123
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0xb83fd2030091eb2b
        Port 1:
                State: Down
                Physical state: Disabled
                Rate: 40
                Base lid: 0
                LMC: 0
                SM lid: 0
                Port GUID: 0xba3fd2fffe91eb2b
CA 'mlx5_4'
        CA type: MT4129
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x9c63c003005546fe
        System image GUID: 0x9c63c003005546fe
        Port 1:
                State: Active
                Rate: 400
                Base lid: 981
                LMC: 0
                SM lid: 359
                Port GUID: 0x9c63c003005546fe
CA 'mlx5_5'
        CA type: MT4129
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x9c63c003005b1e14
        System image GUID: 0x9c63c003005b1e14
        Port 1:
                State: Active
                Rate: 400
                Base lid: 984
                LMC: 0
                SM lid: 359
                Port GUID: 0x9c63c003005b1e14
Node 1:
(base) [szymon.ozog@gh-3714u15 ~]$ lsmod | grep nvidia
nvidia_drm             73728  0
(base) [szymon.ozog@gh-3714u15 ~]$ nvidia-smi topo -m
Legend:
  X    = Self
NIC Legend:
  NIC0: mlx5_0
  NIC1: mlx5_1
  NIC2: mlx5_2
  NIC3: mlx5_3
  NIC4: mlx5_4
  NIC5: mlx5_5
(base) [szymon.ozog@gh-3714u15 ~]$ ibstat
CA 'mlx5_0'
        CA type: MT4129
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x9c63c00300554706
        System image GUID: 0x9c63c00300554706
        Port 1:
                State: Active
                Rate: 400
                Base lid: 977
                LMC: 0
                SM lid: 359
                Port GUID: 0x9c63c00300554706
CA 'mlx5_1'
        CA type: MT4129
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x9c63c0030055487e
        System image GUID: 0x9c63c0030055487e
        Port 1:
                State: Active
                Rate: 400
                Base lid: 978
                LMC: 0
                SM lid: 359
                Port GUID: 0x9c63c0030055487e
CA 'mlx5_2'
        CA type: MT4123
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x58a2e103008dd3ec
        System image GUID: 0x58a2e103008dd3ec
        Port 1:
                State: Active
                Rate: 100
                Base lid: 0
                LMC: 0
                SM lid: 0
                Port GUID: 0x5aa2e1fffe8dd3ec
CA 'mlx5_3'
        CA type: MT4123
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x58a2e103008dd3ed
        Port 1:
                State: Down
                Rate: 40
                Base lid: 0
                LMC: 0
                SM lid: 0
                Port GUID: 0x5aa2e1fffe8dd3ed
CA 'mlx5_4'
        CA type: MT4129
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x9c63c003005546b6
        System image GUID: 0x9c63c003005546b6
        Port 1:
                State: Active
                Rate: 400
                Base lid: 985
                LMC: 0
                SM lid: 359
                Port GUID: 0x9c63c003005546b6
CA 'mlx5_5'
        CA type: MT4129
        Number of ports: 1
        Hardware version: 0
        Node GUID: 0x9c63c003005548ae
        System image GUID: 0x9c63c003005548ae
        Port 1:
                State: Active
                Rate: 400
                Base lid: 987
                LMC: 0
                SM lid: 359
                Port GUID: 0x9c63c003005548ae
What could be the issue here?
Hi
Is that GPU Server NVIDIA DGX?
How did you disable GPU Direct and Enable back?
To narrow it down further, Did you ever try with RDMA Perftest?
** linux-rdma/perftest: Infiniband Verbs Performance Tests
1).what about RDMA Perftest between P2P node? good results?
2).What about GPU Direct RDMA Perftest P2P? GPU Direct RDMA Perfest uses GPU memory other than Host memory.
3).Did you run NCCL single host test without your script?
4).Did you run NCCL 2 nodes without your script?
It needs to be investigated further through CASE. Because there are many things to check about that.
With above info, you should open a case.
/HyungKwang
For disabling I just did NCCL_NET_GDR_LEVEL=0
I managed to resolve the issue by disabling ACS (Troubleshooting — NCCL 2.27.3 documentation)
