Hello currently I am using Mellanox ConnectX-3 Adapter for test
currently the pingpong test that was included in the Mellanox install package (ibv_rc_pingpong) are working
However the tests such as rping and udaddy that were mentioned in the post HowTo Enable, Verify and Troubleshoot RDMA
None of the tests will run
here are the error result below
sungho@c1n15:~$ udaddy -s 172.23.10.30 │sungho@c1n14:~$
udaddy: starting client │sungho@c1n14:~$
udaddy: connecting │sungho@c1n14:~$ udaddy
udaddy: event: RDMA_CM_EVENT_ADDR_ERROR, error: -19 │udaddy: starting server
test complete │
return status -19
I have two servers running connected with a switch,
and the infiniband ethernets are all pingable with each other
and all the ethernets are installed and running
However I have doubts about the arp table
because it doesn’t seem to look like to be connected properly. (listed below)
here is the information of the two servers below
Do you think I need to statistically add the arp table? or is there something fundamentally wrong?
server (A)
sungho@c1n14:/usr/bin$ ibstat
CA ‘mlx4_0’
CA type: MT4099
Number of ports: 1
Firmware version: 2.42.5000
Hardware version: 1
Node GUID: 0x7cfe9003009a7c30
System image GUID: 0x7cfe9003009a7c33
Port 1:
State: Active
Physical state: LinkUp
Rate: 56
Base lid: 3
LMC: 0
SM lid: 3
Capability mask: 0x0251486a
Port GUID: 0x7cfe9003009a7c31
Link layer: InfiniBand
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 172.23.1.1 0.0.0.0 UG 0 0 0 enp1s0f0
172.23.0.0 0.0.0.0 255.255.0.0 U 0 0 0 enp1s0f0
172.23.0.0 0.0.0.0 255.255.0.0 U 0 0 0 ib0
sungho@c1n14:/usr/bin$ arp -n
Address HWtype HWaddress Flags Mask Iface
172.23.10.1 ether 0c:c4:7a:3a:35:88 C enp1s0f0
172.23.10.15 ether 0c:c4:7a:3a:35:72 C enp1s0f0
172.23.1.1 ether 00:1b:21:5b:6a:a8 C enp1s0f0
enp1s0f0 Link encap:Ethernet HWaddr 0c:c4:7a:3a:35:70
inet addr:172.23.10.14 Bcast:172.23.255.255 Mask:255.255.0.0
inet6 addr: fe80::ec4:7aff:fe3a:3570/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:12438 errors:0 dropped:5886 overruns:0 frame:0
TX packets:5861 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2356740 (2.3 MB) TX bytes:836306 (836.3 KB)
ib0 Link encap:UNSPEC HWaddr A0-00-02-20-FE-80-00-00-00-00-00-00-00-00-00-00
inet addr:172.23.10.30 Bcast:172.23.255.255 Mask:255.255.0.0
inet6 addr: fe80::7efe:9003:9a:7c31/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:2044 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:256
RX bytes:0 (0.0 B) TX bytes:616 (616.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:189 errors:0 dropped:0 overruns:0 frame:0
TX packets:189 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:13912 (13.9 KB) TX bytes:13912 (13.9 KB)
server (B)
sungho@c1n15:~$ ibstat
CA ‘mlx4_0’
CA type: MT4099
Number of ports: 1
Hardware version: 1
Node GUID: 0x7cfe9003009a6360
System image GUID: 0x7cfe9003009a6363
Port 1:
State: Active
Rate: 56
Base lid: 1
LMC: 0
SM lid: 3
Capability mask: 0x02514868
Port GUID: 0x7cfe9003009a6361
sungho@c1n15:~$ route -n
sungho@c1n15:~$ arp -n
172.23.10.14 ether 0c:c4:7a:3a:35:70 C enp1s0f0
172.23.10.30 ether 0c:c4:7a:3a:35:70 C enp1s0f0
enp1s0f0 Link encap:Ethernet HWaddr 0c:c4:7a:3a:35:72
inet addr:172.23.10.15 Bcast:172.23.255.255 Mask:255.255.0.0
inet6 addr: fe80::ec4:7aff:fe3a:3572/64 Scope:Link
RX packets:19432 errors:0 dropped:5938 overruns:0 frame:0
TX packets:8783 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8246898 (8.2 MB) TX bytes:1050793 (1.0 MB)
inet addr:172.23.10.31 Bcast:172.23.255.255 Mask:255.255.0.0
inet6 addr: fe80::7efe:9003:9a:6361/64 Scope:Link
TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1232 (1.2 KB)
RX packets:109 errors:0 dropped:0 overruns:0 frame:0
TX packets:109 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7992 (7.9 KB) TX bytes:7992 (7.9 KB)
