Infinite compile time with DT with bad character component
the following code seems to make nvfortran loop infinitely:
module m
  implicit none
  type t
     character(char(1)) :: a  ! erroneous (non-integer) length
  end type
  type(t) :: z = t('a')
end
This is invalid Fortran and should probably be rejected right away.
Thanks,
Harald
Thanks Harold.
I looks like we do give a warning, but not an error. Though it does seem to cause the back-end compiler to hang. I’ve added TPR #33158 and will have engineering take a look.
FYI, the same code causes gfortran 12.2 to segv, though ifort gives the correct error message.
-Mat
Hi Harold,
FYI as of our 23.7, this compiler will now give an error rather a warning and then hang.
% nvfortran -c test.f90 -V23.7
NVFORTRAN-S-0091-Constant expression of wrong data type (test.f90: 4)
  0 inform,   0 warnings,   1 severes, 0 fatal for m
-Mat
