When I execute an insmod of my custom driver, I get the following error.
Strange thing is the the probe has come to the end. So
[ 23.657900] tc358746 2-000e: Probe DONE. Detected tc358746 sensor
[ 23.663063] Internal error: Attempting to execute userspace memory: 86000005 [#1] PREEMPT SMP
[ 23.664841] tc358746 2-000e: tc358746_open:
[ 23.675757] Modules linked in: tc358746(+) fuse zram overlay spidev nvgpu bluedroid_pm ip_tables x_tables
[ 23.685425] CPU: 0 PID: 6350 Comm: insmod Not tainted 4.9.140-tegra #43
[ 23.692032] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 23.698033] task: ffffffc0ca600e00 task.stack: ffffffc0ca7e4000
[ 23.703946] PC is at 0xc
[ 23.706476] LR is at 0xc
[ 23.709007] pc : [<000000000000000c>] lr : [<000000000000000c>] pstate: 40400045
[ 23.716391] sp : ffffffc0ca7e7ab0
[ 23.719702] x29: ffffffc0ca7e7ab0 x28: 0000000000000018
[ 23.725037] x27: 00000000000000f5 x26: 0000000000000030
[ 23.730368] x25: 0000000000000000 x24: 000000000000000c
[ 23.735699] x23: ffffffc0ca7e7ab0 x22: 0000000000000000
[ 23.741030] x21: 00000000000000f5 x20: 0000000000000030
[ 23.746387] x19: 0000000002000011 x18: 0000000000000010
[ 23.751760] x17: 0000000000000000 x16: 0000000000000000
[ 23.757131] x15: ffffffffffffffff x14: ffffff808a145a82
[ 23.762501] x13: ffffff800a145a90 x12: 0000000000000006
[ 23.767871] x11: 0000000005f5e0ff x10: 0000000000000769
[ 23.773241] x9 : 00000000ffffffd0 x8 : ffffff80083d4750
[ 23.778615] x7 : ffffff8009eb4358 x6 : ffffffc0fefdcbf0
[ 23.783982] x5 : ffffffc0fefdcbf0 x4 : 0000000000000000
[ 23.789352] x3 : ffffffc0fefe27f8 x2 : ffffffc0fefdcbf0
[ 23.794719] x1 : ffffffc0ca600e00 x0 : 0000000000000000
[ 23.801613] Process insmod (pid: 6350, stack limit = 0xffffffc0ca7e4000)
[ 23.808335] Call trace:
[ 23.810817] [<000000000000000c>] 0xc
[ 23.814435] [<ffffff800877e4b0>] driver_probe_device+0x100/0x3b8
[ 23.820475] [<ffffff800877e860>] __driver_attach+0xf8/0x100
[ 23.826086] [<ffffff800877be14>] bus_for_each_dev+0x5c/0xa8
[ 23.831688] [<ffffff800877dcb8>] driver_attach+0x30/0x40
[ 23.837030] [<ffffff800877d724>] bus_add_driver+0x20c/0x2a8
[ 23.842632] [<ffffff800877f72c>] driver_register+0x6c/0x110
[ 23.848264] [<ffffff8008ae1bf4>] i2c_register_driver+0x4c/0xb0
[ 23.854253] [<ffffff8000f79018>] tc358746_i2c_driver_init+0x18/0x30 [tc358746]
[ 23.861565] [<ffffff8008083afc>] do_one_initcall+0x44/0x130
[ 23.867228] [<ffffff80081c2d7c>] do_init_module+0x64/0x1a8
[ 23.872803] [<ffffff8008158188>] load_module+0x10a0/0x12d0
[ 23.878369] [<ffffff8008158664>] SyS_finit_module+0xd4/0xe8
[ 23.884017] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
[ 23.889420] ---[ end trace 85fa808659842c8f ]---
[ 24.045953] to_camera_common_data
[ 24.101104] to_camera_common_data
[ 24.104971] tc358746 2-000e: tc358746_power_off: power off
[ 24.110720] tc358746 2-000e: tc358746_power_off: pdata, but NO power_off functionality
[ 24.118795] tc358746 2-000e: camera_common_dpd_enable: csi 0
[ 24.124578] tc358746 2-000e: camera_common_dpd_enable: csi 1
[ 24.130318] tc358746 2-000e: camera_common_dpd_enable: csi 2
[ 24.136315] tc358746 2-000e: camera_common_dpd_enable: csi 3
[ 24.142021] tc358746 2-000e: camera_common_mclk_disable: disable MCLK
[ 24.148634] to_camera_common_data
[ 24.151990] tc358746 2-000e: camera_common_mclk_enable
[ 24.157144] camera_common_mclk_enable
[ 24.160826] tc358746 2-000e: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 24.168709] tc358746 2-000e: camera_common_dpd_disable: csi 0
[ 24.174671] tc358746 2-000e: camera_common_dpd_disable: csi 1
[ 24.180668] tc358746 2-000e: camera_common_dpd_disable: csi 2
[ 24.186631] tc358746 2-000e: camera_common_dpd_disable: csi 3
[ 24.192404] tc358746 2-000e: tc358746_power_on: power on
[ 24.197727] tc358746 2-000e: tc358746_power_on: pdata, but NO power_on functionality
[ 24.230104] to_camera_common_data
[ 24.233496] tc358746 2-000e: tc358746_power_off: power off
[ 24.238994] tc358746 2-000e: tc358746_power_off: pdata, but NO power_off functionality
[ 24.246966] tc358746 2-000e: camera_common_dpd_enable: csi 0
[ 24.252683] tc358746 2-000e: camera_common_dpd_enable: csi 1
[ 24.258452] tc358746 2-000e: camera_common_dpd_enable: csi 2
[ 24.264152] tc358746 2-000e: camera_common_dpd_enable: csi 3
[ 24.269838] tc358746 2-000e: camera_common_mclk_disable: disable MCLK
investigating with gdb don’t shed any light on the problem
(gdb) l *driver_probe_device+0x100
0xbd8 is at /home/builder/Linux/kernelfiles/kernel/kernel-4.9/drivers/base/dd.c:367.
362 if (ret)
363 goto probe_failed;
364 }
365
366 if (dev->bus->probe) {
367 ret = dev->bus->probe(dev);
368 if (ret)
369 goto probe_failed;
370 } else if (drv->probe) {
371 ret = drv->probe(dev);
Any pointers?
