Hi, I am trying to install ARC-OTA using the “docker pull nvcr.io/ea-aerial-sdk/aerial:24-3-arc-ota”. However, the ACCESS is denied, as i do not have early access to ARC-OTA. Please help me with the procedure to get access to the ARC-OTA. I am a member to 6G Developer program, but that is not sufficient i guess.
ARC-OTA with Aerial 24-3 is a much older version. The current accessible one ARC-OTA1.7 is with aerial 25-3. Please following the link Aerial RAN CoLab Over-the-Air — Aerial RAN CoLab Over-the-Air
A newer version Aerial-testbed1.0 ( renamed ARC-OTA after 1.7) with aerial 26-1 is going to be release very soon. It is recommended.
