Based on the sharing below, do you mind giving TorchVision v0.15.0 a try?
Install torchaudio and torchvison from wheel | 4 | 1607 | December 21, 2022 | |
How to install torch, onnxruntimegpu,cuda,opencv ....... (use GPU) on jetson NX jetpack502. I need tutorial . Thanks | 7 | 1794 | June 9, 2023 | |
Pytorch compatibility issues (torch 2.0.0+nv23.5 && torchvision 0.15.1) | 10 | 16786 | June 13, 2023 | |
Installing torch and torchvision in l4t-jetpack based docker image on Jetson Xavier NX | 4 | 2269 | November 28, 2022 | |
Install Pytorch with cuda on Jetson Orin nano Devloper Kit | 13 | 2894 | July 30, 2024 | |
Pytorch & torchversion compatible issue on L4T35.5.0 | 20 | 771 | November 7, 2024 | |
Cannot get Torch met CUDA to work on Jetson Orin | 10 | 2234 | February 26, 2024 | |
Problem with torchvision building from source | 17 | 108 | May 12, 2025 | |
What is the compatible torchvision version for torch-1.14.0a0+44dac51c.nv23.2 installed on AGX ORIN( Ubuntu-22.04, JP-5.1/5.0, Python-3.8, CUDA-11.4) | 19 | 3545 | May 11, 2023 | |
"Hello. I want to install torchaudio with PyTorch 2.0.0." | 4 | 490 | July 26, 2024 |
