1. You can find the Torch and corresponding TorchVision version below:
2 To modify the eval_coco.py for the YOLOv5 model,
you can update the source, that calculates the bounding box, with the official YOLOv5 implementation below:
Hello @AastaLLL ,
Thank you very much for the suggestion. I will try it and let you know about the result :)
Harry
Hello again @AastaLLL ,
I have installed the new Jestpack 5.0.2 on my Jetson AGX Orin because there is no Torch with CUDA for my previous version of Jetpack 5.0.1 DP.
After that I have installed pyTorch with CUDA from here it is the 1.13 version I have no choices for this Jetpack.
After that, I cloned the YOLOv5 repo and installed the latest version of Torchvision because I couldnβt find the right version for my version of Torch + CUDA here in the matrix.
So to make it clear, I have installed:
Now when running the YOLOv5 val.py script I have this error below:
(venv_yolov5) usr@ubuntu:/media/usr/B21F-F81E/ORIN/yolov5/yolov5$ python val.py --weights yolov5s.pt --data coco128.yaml --img 640
/home/usr/Documents/venv_yolov5/lib/python3.8/site-packages/torchvision/io/image.py:13: UserWarning: Failed to load image Python extension:
warn(f"Failed to load image Python extension: {e}")
val: data=/media/usr/B21F-F81E/ORIN/yolov5/yolov5/data/coco128.yaml, weights=['yolov5s.pt'], batch_size=32, imgsz=640, conf_thres=0.001, iou_thres=0.6, max_det=300, task=val, device=, workers=8, single_cls=False, augment=False, verbose=False, save_txt=False, save_hybrid=False, save_conf=False, save_json=False, project=runs/val, name=exp, exist_ok=False, half=False, dnn=False
YOLOv5 π v6.2-183-gc98128f Python-3.8.10 torch-1.13.0a0+08820cb0.nv22.07 CUDA:0 (Orin, 30536MiB)
Downloading https://github.com/ultralytics/yolov5/releases/download/v6.2/yolov5s.pt to yolov5s.pt...
100%|βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ| 14.1M/14.1M [00:00<00:00, 22.5MB/s]
Fusing layers...
YOLOv5s summary: 213 layers, 7225885 parameters, 0 gradients
Dataset not found β οΈ, missing paths ['/media/usr/B21F-F81E/ORIN/yolov5/datasets/coco128/images/train2017']
Downloading https://ultralytics.com/assets/coco128.zip to coco128.zip...
100%|βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ| 6.66M/6.66M [00:00<00:00, 36.4MB/s]
Dataset download success β
(3.8s), saved to /media/usr/B21F-F81E/ORIN/yolov5/datasets
Downloading https://ultralytics.com/assets/Arial.ttf to /home/usr/.config/Ultralytics/Arial.ttf...
100%|βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ| 755k/755k [00:00<00:00, 33.3MB/s]
val: Scanning '/media/usr/B21F-F81E/ORIN/yolov5/datasets/coco128/labels/train2017' images and labels...126 found, 2 missing, 0 empty, 0 corrupt: 100%|ββββββββββ| 128/128 [00:00<00:00, 2962.29it/s]
val: New cache created: /media/usr/B21F-F81E/ORIN/yolov5/datasets/coco128/labels/train2017.cache
Class Images Instances P R mAP50 mAP50-95: 0%| | 0/4 [00:01<?, ?it/s]
File "val.py", line 406, in <module>
main(opt)
File "val.py", line 379, in main
run(**vars(opt))
File "/home/usr/Documents/venv_yolov5/lib/python3.8/site-packages/torch/autograd/grad_mode.py", line 27, in decorate_context
return func(*args, **kwargs)
File "val.py", line 219, in run
preds = non_max_suppression(preds,
File "/media/usr/B21F-F81E/ORIN/yolov5/yolov5/utils/general.py", line 923, in non_max_suppression
i = torchvision.ops.nms(boxes, scores, iou_thres) # NMS
File "/home/usr/Documents/venv_yolov5/lib/python3.8/site-packages/torchvision/ops/boxes.py", line 40, in nms
_assert_has_ops()
File "/home/usr/Documents/venv_yolov5/lib/python3.8/site-packages/torchvision/extension.py", line 33, in _assert_has_ops
raise RuntimeError(
RuntimeError: Couldn't load custom C++ ops. This can happen if your PyTorch and torchvision versions are incompatible, or if you had errors while compiling torchvision from source. For further information on the compatible versions, check https://github.com/pytorch/vision#installation for the compatibility matrix. Please check your PyTorch version with torch.__version__ and your torchvision version with torchvision.__version__ and verify if they are compatible, and if not please reinstall torchvision so that it matches your PyTorch install.
Exception in thread Thread-7:
File "/usr/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/lib/python3.8/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "/home/usr/Documents/venv_yolov5/lib/python3.8/site-packages/torch/utils/data/_utils/pin_memory.py", line 28, in _pin_memory_loop
r = in_queue.get(timeout=MP_STATUS_CHECK_INTERVAL)
File "/usr/lib/python3.8/multiprocessing/queues.py", line 116, in get
return _ForkingPickler.loads(res)
File "/home/usr/Documents/venv_yolov5/lib/python3.8/site-packages/torch/multiprocessing/reductions.py", line 297, in rebuild_storage_fd
fd = df.detach()
File "/usr/lib/python3.8/multiprocessing/resource_sharer.py", line 57, in detach
with _resource_sharer.get_connection(self._id) as conn:
File "/usr/lib/python3.8/multiprocessing/resource_sharer.py", line 87, in get_connection
c = Client(address, authkey=process.current_process().authkey)
File "/usr/lib/python3.8/multiprocessing/connection.py", line 508, in Client
answer_challenge(c, authkey)
File "/usr/lib/python3.8/multiprocessing/connection.py", line 752, in answer_challenge
message = connection.recv_bytes(256) # reject large message
File "/usr/lib/python3.8/multiprocessing/connection.py", line 216, in recv_bytes
buf = self._recv_bytes(maxlength)
File "/usr/lib/python3.8/multiprocessing/connection.py", line 414, in _recv_bytes
buf = self._recv(4)
File "/usr/lib/python3.8/multiprocessing/connection.py", line 379, in _recv
chunk = read(handle, remaining)
ConnectionResetError: [Errno 104] Connection reset by peer
So we can see that it detect my Jetson it says (Orin, 30536MiB), so Torch + CUDA is succesfully installed.
However, when importing Torchvision in python, I have this WARNING message bellow:
Python 3.8.10 (default, Jun 22 2022, 20:18:18)
[GCC 9.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torchvision
I believe that Torchvision has not the right version or it is not installed the right way of my Jetson.
So my question is how to install Torchvision with CUDA or how to install it the right way with a version that is compatible with the version of Torch+CUDA on my Jetson AGX Orin.
Thank you in advance @AastaLLL
Harry
Do you install TorchVision v0.13.1 (1.13.1 is mentioned above)?
We are going to give it a try.
Will share more information with you later.
Yes indeed, I have installed TorchVision v0.13.1 and Torch (pyTorch) v1.13 + CUDA as Nvidia suggested.
Below is my pip list:
I will be waiting your results :)
Thank you
I have ran the validation on google collab to see if it works there and which Torch and Torch version were used, here below are the result from google collab:
So I think and according to this they have both Torch and Torchvision with CUDA.
So I must install Torchvision with CUDA on my Jetson as well. Maybe this will help you :)
Harry
Did you mean if using TorchVision with CUDA support that Torch+TorchVision can work?
Hello @AastaLLL ,
Yes, I am using only Torch with CUDA support. However, Torchvision does not have CUDA support, perhaps this cause the issue?
I did not find any tutorial on how to install Torchvision with CUDA support for Jetson devices.
I tried to run the validation script of yolov5 in google collab provided by yolov5 and I printed the versions of Torch and Torchvision and found that both has CUDA support.
I am pretty sure that the issue is from torchvision. Because I have installed Torch with CUDA support according to the Nvidia official tutorial and it can detect very well my GPU:
I think that I need to install the right way Torchvision with CUDA support on my Jetson AGX Orin, what do you think?
Thank you
Harry
Hello @AastaLLL ,
I think I have resolved the problem.
Today 05/10/2022 Nvidia has uploaded a new version of Torch+CUDA support compatible with Jetpack 5.0.2.
So I have installed the last one and I have build Torchvision from source here.
After doing that, I have Torch and TorchVision both with CUDA support I think.
I tried and ran the val.py
scipt from yolov5 and it worked. Now I wil try to run it using a TensorRT engine, I hope there will be no issues. I will keep you updated.
Thank you very much :)
Harry
Thanks for the testing.
Itβs good to know it works now.
Hello @AastaLLL ,
It works now, the solution is to install the latest version of Torch+CUDA support from Nvidia and build TorchVision from source.
However, I have a very bad result on yolov5 INT8 quatified and calibrated engine with EfficientDet scripts here.
So I think the calibration is not well done for yolov5, what do you think?
Could you please, tell me how to do the right INT8 calibration for yolov5 using JPEG/JPG image format from COCO dataset like the EfficientDet scripts do?
I get this warning below when generating the engine (maybe this could help you)
I found this thread here as well maybe it is not the calibration but TensorRT!
[TRT] [W] - Subnormal FP16 values detected.
[TRT] [W] If this is not the desired behavior, please modify the weights or retrain with regularization to reduce the magnitude of the weights.
[TRT] [W] Weights [name=Conv_195 + PWN(PWN(Sigmoid_196), Mul_197).weight] had the following issues when converted to FP16:
[TRT] [W] Weights [name=Conv_198.weight] had the following issues when converted to FP16:
Thank you very much for your help @AastaLLL :)
Harry
Letβs clarify the issue comes from first.
If the fp32 or fp16 mode is used, did you get the correct output from the sample?
fp32 and fp16 donβt require calibration and itβs expected that they can work normally.
Hello @AastaLLL ,
I ran yolov5-n fp16 mode without calibration because it is not required, I still have the warning output below:
[TRT] [W] Weights [name=Conv_182 || Conv_191.weight] had the following issues when converted to FP16:
[TRT] [W] Weights [name=Conv_185 + PWN(PWN(Sigmoid_186), Mul_187).weight] had the following issues when converted to FP16:
[TRT] [W] Weights [name=Conv_188 + PWN(PWN(Sigmoid_189), Mul_190).weight] had the following issues when converted to FP16:
etc....
However, my results are pretty good, I have 28.1mAP which is the same as yolov5-n full precision here.
Now for INT8 I need to do calibration, so I used the EfficientDet scipts but I have 0 mAP accuracy.
Thank you :)
Itβs good to know that the fp16 mode works well.
We want to reproduce this issue internally.
Do you apply some custom modification to the sample for YOLOv5?
If yes, could you share the sample for fp16 inferene and int8 calibration with us?
Hello @AastaLLL ,
I am using the ONNX yolov5-n model with batchsize = 1, generated from yolov5 official repo, I will share it with you as well.
b1_yolov5n.onnx (7.5 MB)
For the INT8 quatification with calibration I have used the EfficientDet Nvidia official repo I will share with you the calibration cache file. I have used 25000 images from COCO test dataset to calibrate.
b1_yolov5n_25000.cache (6.4 KB)
Now to get the engine, you can either generated from trtexec or from EfficientDet build_engine.py
script here.
if you could please, try to do the calibration and generating the calibrated engine from the ONNX model above (so we have the same model) and 25000 images from COCO test dataset using build_engine.py
script so we can compare the two results. Because I think the issue comes from the calibration.
Now for the results I have used the val.py
script from yolov5 here
I have used this command below.
$ python3 val.py --weights b1_yolov5n.engine --data coco.yaml --img 640
NOTE:
you must put the generated calibrated engine in --weights
I am waiting for your results :)
Thank you in advance.
Harry
Just want to confirm first.
Did you apply the calibration on Orin directly?
Since the calibration is hardware dependent, you will need to generate the file on Orin.
Hello @AastaLLL ,
Yes indeed, I applied everything on Orin directly.
Have you succeed? Do you have a good results?
Thank you.
Just found that there is a sample in the YOLOv5 that calibrates with Deepstream.
Although it is not a python sample, the calibration is verified and should work.
Could you please give it a try?
Hello @AastaLLL ,
I will try it after, because I donβt have enough time to test and see if it works. I will teste it in the few future.
Thank you for your help.
