• Hardware Platform (Jetson / GPU) Jetson Orin NX (8GB)
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
• TensorRT Version JP 5.1.2 Standard (8,5?)
• NVIDIA GPU Driver Version (valid for GPU only) JP 5.1.2 standard
• Issue Type( questions, new requirements, bugs) Question
Trying to create and INT8 optimized TRT engine from my YOLOv4 ONNX model for use with DeepStream-YOLO / nvinfer. I am using the same model file and the same Calibration Images as from Deepstream 6.0.0. I am running the int8 calibration inside Deepstream_app as described here: DeepStream-Yolo/docs/YOLOv5.md at master · marcoslucianops/DeepStream-Yolo · GitHub (without the Ultralytics part at the beginning)
With DS 6.0 on a Jeston NX (not Orin) this resulted in a model with 94% recall over my test dataset. With DS 6.3 and Orin NX i only get 87% (tested many, many calibration runs with different parameters).
config_nvinfer_primary.txt
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
custom-network-config=yolov4.cfg
model-file=yolov4.weights
model-engine-file=model_b1_gpu0_int8.engine
int8-calib-file=calib.table
labelfile-path=dc_vehicles.training.names
batch-size=1
network-mode=1
num-detected-classes=14
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=0
symmetric-padding=1
force-implicit-batch-dim=0
workspace-size=6000
#parse-bbox-func-name=NvDsInferParseYolo
parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
# DLA does not make sense for us with JP 5.1.2
# because our model requires a lot of GPU fallbacks, reducing speed by 40%.
#enable-dla=1
#use-dla-core=0
#gpu-fallback=1
[class-attrs-all]
nms-iou-threshold=0.3
pre-cluster-threshold=0.3
topk=300
Is this something others also experience? This reduction in detection rates makes it a problem for us to upgrade to Jetpack 5.
