Issue with yolov8s-seg conversion from onnx to engine
Facing the following issues while converting my yolov8 seg model from onnx to tensorrt :
/usr/src/tensorrt/bin/trtexec --onnx=yolov8s-seg.onnx --saveEngine=yolov8s-seg.engine
&&&& RUNNING TensorRT.trtexec [TensorRT v8401] # /usr/src/tensorrt/bin/trtexec --onnx=yolov8s-seg.onnx --saveEngine=yolov8s-seg.engine
[10/28/2024-19:31:33] [I] === Model Options ===
[10/28/2024-19:31:33] [I] Format: ONNX
[10/28/2024-19:31:33] [I] Model: yolov8s-seg.onnx
[10/28/2024-19:31:33] [I] Output:
[10/28/2024-19:31:33] [I] === Build Options ===
[10/28/2024-19:31:33] [I] Max batch: explicit batch
[10/28/2024-19:31:33] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[10/28/2024-19:31:33] [I] minTiming: 1
[10/28/2024-19:31:33] [I] avgTiming: 8
[10/28/2024-19:31:33] [I] Precision: FP32
[10/28/2024-19:31:33] [I] LayerPrecisions:
[10/28/2024-19:31:33] [I] Calibration:
[10/28/2024-19:31:33] [I] Refit: Disabled
[10/28/2024-19:31:33] [I] Sparsity: Disabled
[10/28/2024-19:31:33] [I] Safe mode: Disabled
[10/28/2024-19:31:33] [I] DirectIO mode: Disabled
[10/28/2024-19:31:33] [I] Restricted mode: Disabled
[10/28/2024-19:31:33] [I] Build only: Disabled
[10/28/2024-19:31:33] [I] Save engine: yolov8s-seg.engine
[10/28/2024-19:31:33] [I] Load engine:
[10/28/2024-19:31:33] [I] Profiling verbosity: 0
[10/28/2024-19:31:33] [I] Tactic sources: Using default tactic sources
[10/28/2024-19:31:33] [I] timingCacheMode: local
[10/28/2024-19:31:33] [I] timingCacheFile:
[10/28/2024-19:31:33] [I] Input(s)s format: fp32:CHW
[10/28/2024-19:31:33] [I] Output(s)s format: fp32:CHW
[10/28/2024-19:31:33] [I] Input build shapes: model
[10/28/2024-19:31:33] [I] Input calibration shapes: model
[10/28/2024-19:31:33] [I] === System Options ===
[10/28/2024-19:31:33] [I] Device: 0
[10/28/2024-19:31:33] [I] DLACore:
[10/28/2024-19:31:33] [I] Plugins:
[10/28/2024-19:31:33] [I] === Inference Options ===
[10/28/2024-19:31:33] [I] Batch: Explicit
[10/28/2024-19:31:33] [I] Input inference shapes: model
[10/28/2024-19:31:33] [I] Iterations: 10
[10/28/2024-19:31:33] [I] Duration: 3s (+ 200ms warm up)
[10/28/2024-19:31:33] [I] Sleep time: 0ms
[10/28/2024-19:31:33] [I] Idle time: 0ms
[10/28/2024-19:31:33] [I] Streams: 1
[10/28/2024-19:31:33] [I] ExposeDMA: Disabled
[10/28/2024-19:31:33] [I] Data transfers: Enabled
[10/28/2024-19:31:33] [I] Spin-wait: Disabled
[10/28/2024-19:31:33] [I] Multithreading: Disabled
[10/28/2024-19:31:33] [I] CUDA Graph: Disabled
[10/28/2024-19:31:33] [I] Separate profiling: Disabled
[10/28/2024-19:31:33] [I] Time Deserialize: Disabled
[10/28/2024-19:31:33] [I] Time Refit: Disabled
[10/28/2024-19:31:33] [I] Inputs:
[10/28/2024-19:31:33] [I] === Reporting Options ===
[10/28/2024-19:31:33] [I] Verbose: Disabled
[10/28/2024-19:31:33] [I] Averages: 10 inferences
[10/28/2024-19:31:33] [I] Percentile: 99
[10/28/2024-19:31:33] [I] Dump refittable layers:Disabled
[10/28/2024-19:31:33] [I] Dump output: Disabled
[10/28/2024-19:31:33] [I] Profile: Disabled
[10/28/2024-19:31:33] [I] Export timing to JSON file:
[10/28/2024-19:31:33] [I] Export output to JSON file:
[10/28/2024-19:31:33] [I] Export profile to JSON file:
[10/28/2024-19:31:33] [I] === Device Information ===
[10/28/2024-19:31:33] [I] Selected Device: Orin
[10/28/2024-19:31:33] [I] Compute Capability: 8.7
[10/28/2024-19:31:33] [I] SMs: 8
[10/28/2024-19:31:33] [I] Compute Clock Rate: 1.3 GHz
[10/28/2024-19:31:33] [I] Device Global Memory: 30535 MiB
[10/28/2024-19:31:33] [I] Shared Memory per SM: 164 KiB
[10/28/2024-19:31:33] [I] Memory Bus Width: 128 bits (ECC disabled)
[10/28/2024-19:31:33] [I] Memory Clock Rate: 1.3 GHz
[10/28/2024-19:31:33] [I] TensorRT version: 8.4.1
[10/28/2024-19:31:34] [I] [TRT] [MemUsageChange] Init CUDA: CPU +218, GPU +0, now: CPU 242, GPU 7604 (MiB)
[10/28/2024-19:31:38] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +351, GPU +331, now: CPU 612, GPU 7953 (MiB)
[10/28/2024-19:31:38] [I] Start parsing network model
[10/28/2024-19:31:38] [I] [TRT] ----------------------------------------------------------------
[10/28/2024-19:31:38] [I] [TRT] Input filename: yolov8s-seg.onnx
[10/28/2024-19:31:38] [I] [TRT] ONNX IR version: 0.0.8
[10/28/2024-19:31:38] [I] [TRT] Opset version: 16
[10/28/2024-19:31:38] [I] [TRT] Producer name: pytorch
[10/28/2024-19:31:38] [I] [TRT] Producer version: 1.13.0
[10/28/2024-19:31:38] [I] [TRT] Domain:
[10/28/2024-19:31:38] [I] [TRT] Model version: 0
[10/28/2024-19:31:38] [I] [TRT] Doc string:
[10/28/2024-19:31:38] [W] [TRT] onnx2trt_utils.cpp:367: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[10/28/2024-19:31:39] [W] [TRT] Tensor DataType is determined at build time for tensors not marked as input or output.
[10/28/2024-19:31:39] [W] [TRT] onnx2trt_utils.cpp:395: One or more weights outside the range of INT32 was clamped
[10/28/2024-19:31:39] [I] [TRT] No importer registered for op: RoiAlign. Attempting to import as plugin.
[10/28/2024-19:31:39] [I] [TRT] Searching for plugin: RoiAlign, plugin_version: 1, plugin_namespace:
[10/28/2024-19:31:39] [E] [TRT] ModelImporter.cpp:773: While parsing node number 608 [RoiAlign → “onnx::Cast_815”]:
[10/28/2024-19:31:39] [E] [TRT] ModelImporter.cpp:774: — Begin node —
[10/28/2024-19:31:39] [E] [TRT] ModelImporter.cpp:775: input: “onnx::Shape_354”
input: “selected_boxes”
input: “onnx::Mul_752”
output: “onnx::Cast_815”
op_type: “RoiAlign”
attribute {
s: “half_pixel”
type: STRING
attribute {
s: “avg”
type: STRING
attribute {
i: 160
type: INT
attribute {
i: 160
type: INT
attribute {
i: 0
type: INT
attribute {
f: 0.25
type: FLOAT
[10/28/2024-19:31:39] [E] [TRT] ModelImporter.cpp:776: — End node —
[10/28/2024-19:31:39] [E] [TRT] ModelImporter.cpp:778: ERROR: builtin_op_importers.cpp:4890 In function importFallbackPluginImporter:
[8] Assertion failed: creator && “Plugin not found, are the plugin name, version, and namespace correct?”
[10/28/2024-19:31:39] [E] Failed to parse onnx file
[10/28/2024-19:31:39] [I] Finish parsing network model
[10/28/2024-19:31:39] [E] Parsing model failed
[10/28/2024-19:31:39] [E] Failed to create engine from model or file.
[10/28/2024-19:31:39] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8401] # /usr/src/tensorrt/bin/trtexec --onnx=yolov8s-seg.onnx --saveEngine=yolov8s-seg.engine
I am using jetson orin, with
Jetpack : 5.0.2
Cuda : 11.4
tensorrt : 8.4.1.5
onnx: 1.12.0
onnxsim : 0.4.36
We support jetson_multimedia_api and gstreamer. Please make sure you have checked the document:
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/Multimedia.html
https://docs.nvidia.com/jetson/archives/r36.3/ApiReference/index.html
There are some examples in
Q: Is there any example of running RTSP streaming?
Q: Is there an example for running UDP streaming?
Q: I have a USB camera. How can I launch it on AGX Orin?
For further issues, please share a method to replicate the issue through gstreamer command, or either sample. We will set up developer kit and check.
Hi, seems your answer is different from what I asked. Could you please look into this again ?
My issue is similar to this : TRT Fails to parse ONNX Model (yolov8 Segmentation)
But in my case, I am already using the latest version mentioned in the solved post
op_type: “RoiAlign”
The layer is not supported in TensorRT 8.4.
You can find the supported matrix below:
Please try the model with a newer TensorRT version as it is added after TensoerRT 8.5.
