Converting yolov4 model to engine file in deepstream
• Hardware Platform (Jetson / GPU) Orin
• DeepStream Version 7.0
**• JetPack Version (valid for Jetson only)**6.0+b87
• TensorRT Version8.6.2.3-1+cuda12.2
Yolov4 model is trained using TAO lib. The hd5 file is exported to int8 onnx file using the following command.
yolo_v4 export -m /workspace/tao_tutorials/data/experiment_dir_unpruned/resnet18/weights/yolov4_resnet18_epoch_080.hdf5 -k nvidia_tlt -e /workspace/tao_tutorials/notebooks/tao_launcher_starter_kit/yolo_v4/specs/yolo_v4_train_resnet18_kitti.txt --batch_size 3 --data_type int8 --cal_image_dir /workspace/tao_tutorials/data/images --batches 10 --cal_cache_file /workspace/tao_tutorials/data/experiment_dir_unpruned/resnet18/weights/yolov4_resnet18.cal --cal_data_file /workspace/tao_tutorials/data/experiment_dir_unpruned/resnet18/weights/yolov4_resnet18.tensorfile
I have yolov4_resnet18.tensorfile and yolov4_resnet18_epoch_080_int8.onnx
To convert onnx to engine in deepstream, the following config is used.
[property]
gpu-id=0
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=1
onnx-file=../../models/yolo4_resnet18/yolov4_resnet18_epoch_080_int8.onnx
#int8-calib-file=../../models/yolo4_resnet18/yolov4_resnet18.tensorfile
labelfile-path=../../models/yolo4_resnet18/labels.txt
model-engine-file=../../models/yolo4_resnet18/yolov4_resnet18_epoch_080_int8.onnx_b3_gpu0_int8.engine
infer-dims=3;384;1248
maintain-aspect-ratio=1
uff-input-order=0
uff-input-blob-name=Input
batch-size=3
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=3
interval=0
gie-unique-id=1
is-classifier=0
#network-type=0
#no cluster
cluster-mode=3
output-blob-names=BatchedNMS
parse-bbox-func-name=NvDsInferParseCustomBatchedNMSTLT
custom-lib-path=/opt/nvidia/deepstream/deepstream-7.0/sources/apps/sample_apps/deepstream_tlt_apps/post_processor/libnvds_infercustomparser_tlt.so
I suspect that the engine file converted is not int8 because the file name has fp16 like yolov4_resnet18_epoch_080_int8.onnx_b3_gpu0_fp16.engine
I know that int engine file conversion needs calibration file.
But in the config file, if int8-calib-file=../../models/yolo4_resnet18/yolov4_resnet18.tensorfile is uncommented, the app crushed.
What is the correct way of int8 engine conversion for yolo4 model?
Could you attach the log from when deepstream generated the engine file?
You can also attach your onnx and cal file. We can try that on our side.
The model is sent via url in private message. Pls let me know if u can’t download.
I don’t have cal file. Export produced only tensorfile.
Where do I find log file for generation of engine file?
The messages came out during conversion are as follows.
atic@ubuntu:/opt/nvidia/deepstream/deepstream-7.0/sources/apps/sample_apps/st_andrew$ ./deepstream-app -c ../../../../samples/configs/deepstream-app/standrew_main.txt
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/../../models/yolo4_resnet18/yolov4_resnet18_epoch_080_int8.onnx_b3_gpu0_int8.engine open error
0:00:07.992059145  4904 0xaaab00757760 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2083> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/../../models/yolo4_resnet18/yolov4_resnet18_epoch_080_int8.onnx_b3_gpu0_int8.engine failed
0:00:08.364638463  4904 0xaaab00757760 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2188> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/../../models/yolo4_resnet18/yolov4_resnet18_epoch_080_int8.onnx_b3_gpu0_int8.engine failed, try rebuild
0:00:08.370567363  4904 0xaaab00757760 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2109> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:372: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: onnx2trt_utils.cpp:400: One or more weights outside the range of INT32 was clamped
WARNING: [TRT]: builtin_op_importers.cpp:5219: Attribute caffeSemantics not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
WARNING: INT8 calibration file not specified. Trying FP16 mode.
WARNING: [TRT]: DLA requests all profiles have same min, max, and opt value. All dla layers are falling back to GPU
WARNING: [TRT]: TensorRT encountered issues when converting weights between types and that could affect accuracy.
WARNING: [TRT]: If this is not the desired behavior, please modify the weights or retrain with regularization to adjust the magnitude of the weights.
WARNING: [TRT]: Check verbose logs for the list of affected weights.
WARNING: [TRT]: - 66 weights are affected by this issue: Detected subnormal FP16 values.
WARNING: [TRT]: - 33 weights are affected by this issue: Detected values less than smallest positive FP16 subnormal value and converted them to the FP16 minimum subnormalized value.
0:24:32.996011443  4904 0xaaab00757760 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2141> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-7.0/samples/models/yolo4_resnet18/yolov4_resnet18_epoch_080_int8.onnx_b3_gpu0_fp16.engine successfully
INFO: [FullDims Engine Info]: layers num: 5
0   INPUT  kFLOAT Input           3x384x1248      min: 1x3x384x1248    opt: 3x3x384x1248    Max: 3x3x384x1248
1   OUTPUT kINT32 BatchedNMS      1               min: 0               opt: 0               Max: 0
2   OUTPUT kFLOAT BatchedNMS_1    200x4           min: 0               opt: 0               Max: 0
3   OUTPUT kFLOAT BatchedNMS_2    200             min: 0               opt: 0               Max: 0
4   OUTPUT kFLOAT BatchedNMS_3    200             min: 0               opt: 0               Max: 0
0:24:33.524291723  4904 0xaaab00757760 INFO                 nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/config_infer_standrew.txt sucessfully
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
**PERF:  FPS 0 (Avg)	FPS 1 (Avg)	FPS 2 (Avg)
**PERF:  0.00 (0.00)	0.00 (0.00)	0.00 (0.00)
** INFO: <bus_callback:291>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NvMMLiteBlockCreate : Block : BlockType = 279
** INFO: <bus_callback:277>: Pipeline running
If you don’t have a cal file, you cannot use the int8 mode. As you can see from your log, when you don’t set the cal file, we changed that to the FP16 mode. But when you set a wrong cal file, this may cause some issues.
So how can I export to produce cal file?
You can see in earlier post for producing onnx file for int8 using TAO. The command doesn’t produce cal file.
We suggest that you file this topic on the TAO Forum. You can get a more professional response about how generate a cal file. And then discuss Deepstream-related issues after cal file can be generated normally here.
